What is the replacement t con of lc 37bx5m. - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
There is no replacement number. You should use the original number fitted with the TV.
Posted on Apr 27, 2015
2 Suggested Answers
gopakumarg43
  • 75571 Answers
SOURCE: I have a Sharp Aquos
Hello
The cause of this problem can't be predicted. As far as sond is OK, it means that the sections, video IF, sound IF, tuner and all other fuctions except the video section is working well. There are mainly two reasons for this video fault. The first one is DAC trouble itself. if it is detected by test, the DAC board should be repaced. There is not replacable part in that board, as all components are soeered into it by machines. They can't be repalced by normal desoldering and soldering methods. Card replacement is the only remedy. The second possible fault is, no power entering to this board. it can be tested by normal methods by using a digital multimeter. A high quality digital multimeter should be used, as the components of this side are very sensitive to external loads. ordinary multimeter will make a load to it whilw testing it live. You must have through knolwdge in electronics, especially digital electronics, as this part is digtal section.
Just do one thing first. Switch off the set by remote control [Standby state]; keep it as for about 1 minute, unplug the power socket from the wall, keep it as for 2 minutes. Thus reset will complete. Switch it ON after that, and check whether reset process help you. If not, no doubt that the video card is damaged and should be replaced.
If you want anymore assistance, get me by Fixya. I'm happy to assist you. OK.
Posted on Mar 30, 2011
Lc-60le835u screen going black,turned off for minute,turn back on okay for 15 minutes then screen goes black again, now screen is always black the sound is ok,need 2 know what it is I need to replace?
I would only guess on this without testing it and having a repair guide, but the PCB that controls the screen display is called the "T-Con" PCB
Nov 04, 2016 | Sharp Lc-60le835u Led Tv
T-con board or maim Board issue? Disconnected T-con from the main board and got back light! sharp lc-55le55ou
Hook the Tcon cable back up and do this. With a program running on the TV, shine a flashlight in the screen. If you can't see movement from the program, then the Tcon board is bad. you can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 02, 2016 | Sharp Aquos Televison & Video
How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
Sep 13, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I need a DUNKKD530UJ01. This is a top tcon board for LC-65D90U. Who has one?
Couldn't find your specificcion but maybe another T-Con board might work too
Try
Sharp DUNTKD530UJ01 (KD530, XD530WJ) T-Con Board for LC-65D90U
Sharp DUNTKD530UJ01 KD530 XD530WJ Con Board for LC 65D90U
Or call Shopjimmy see Contact/Helps on webpage
They know about EVERYTHING about parts!
May 11, 2015 | Sharp LC-65D90U 65 in. LCD Television
Filaimat light off with in 2 seconf
It sounds that there is some fault to its main digital board. Contact any service technician. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help. More than Ten Lakh viewers cannot be wrong.
May 21, 2013 | Sharp LC-37BX5M 37 in. LCD TV
Sharp T-Con Board for LC-37D43U
I suspect it to be a back- light problem. Check the CCFL lamps. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | Televison & Video
How do I remove Sharp Aquos runtk4242tpza t-con board
If you have some knowledge in electronics, you can replace it by yourself, as there is no further adjustments should be done with this replacement work. You must have patience and concentration. That is all. Visit this site. It has details about how replace a T'Con board. Actually, it refers to an other set, but the work is common for all LCD tVs. Pull up older posts there. Check this link, and select the site.
Jul 17, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a 15 inch Advent LCD TV in my kitchen. I turned it on today and have no picture. When I switch stations I get a picture for a minute then it is replaced with vertical lines or a blank screen with...
U have vertical lines for a few second.That mean u tv have a dead board call the T-CON decoders is board.This T-CON decoders board sit at the bottom wright in the middle of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Dec 11, 2010 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
