Question about Toshiba Office Equipment & Supplies
My Toshiba 230 copier when start copy auto shutting down
Pls help me
    Champion:
    New Friend:
  • Toshiba Expert
  • 236 Answers
0+8>206="20"
Posted on Jun 26, 2016
  • 32 Answers
SOURCE: toshiba copier,6570, make double side copies
On the main touch screen there are 4 touch buttons. The bottom left on should say : Simplex 1-1. If you tap on it you will see duplex 1-2 , duplex 2-2, Split 1-2 and so on.
Hope this helps
Posted on Feb 04, 2008
  • 990 Answers
SOURCE: xe80 copies coming out almost black on auto or light
Hello sir; Just replace drum cartridge it will take care your problem, GOOD LUCK!
Posted on Jan 07, 2009
  • 990 Answers
SOURCE: black copies copier toshiba studio 35
Hello sir; It seem like you need periodical service, which is need to replace drum , cleaning blade, and developer etc.
Posted on Apr 29, 2009
  • 643 Answers
SOURCE: display F120 error in my Toshiba etudio 230
F120 indicates database abnormality.
What u can do:
1. Rebuild the database ( 08-684 )
2. If the error is not recovered, initialize the HDD. (Enter “2” at 08-690.)
PS: Press "0+8" & ON the machine in order to enter setting mode.
Posted on Jul 29, 2009
  • 990 Answers
SOURCE: have a Toshiba 230 copier but would get it as printer
Hello sir; Does this model come with printer option? if not, you can not use it as your pc.
Posted on Sep 18, 2009
I shut down my toshiba copier 282 in the right way . It gives me the message shutting down in progress but it doesn't shut down automatically as before. It only shuts down with the on/off switch
AD+206
Auto Shut Off Mode timer
setting (Auto Shut Off
Mode/Sleep Mode)
ALL Refer to
content
<0-20>
SYS Timer to turn OFF the
power or to enter the
Sleep Mode automatically
when the equipment
has not been
used
0: 3min. 1: 5min.
2: 10min. 3: 15min.
4: 20min. 5: 25min.
6: 30min. 7: 40min.
8: 50min. 9: 60min.
10: 70min.
11: 80min.
12: 90min.
13: 100min.
14: 110min.
15: 120min.
16: 150min.
17: 180min.
18: 210min.
19: 240min.
20: Not used
check this or update firmwear
Sep 29, 2016 | Toshiba Office Equipment & Supplies
Tip
Copiers Sharp AL-1631 AL-1641CS DESCRIPTION OF SPECIAL FUNCTIONS
Toner save mode
Reduces toner consumption by approximately 10%.
Power save modes
The unit has two power save modes of operation: preheat mode and auto power
shut-off mode.
Preheat mode
When the unit enters the preheat mode, the power save indicator will light up
and other indicators will remain on or off as before. In this condition, the fuser in
the unit is maintained at a lower heat level, thereby saving power. To copy from
the preheat mode, make desired copier selections and press the start key
using the normal copying procedure.
Auto power shut-off mode
When the unit enters the auto power shut-off mode, the power save ( ) indicator
will light up and other indicators except the ONLINE indicator will go out. The auto
power shut-off mode saves more power than the preheat mode but requires a
longer time before starting copying. To copy from the auto power shut-off mode,
press the start key. Then make desired copier selections and press the star key using the normal copying procedure.
Auto clear
The unit returns to the initial settings a preset amount of time after the end of copy, or
scanner job. This preset amount of time (auto clear time) can be changed.
Stream feeding mode
For description of the stream feeding mode, see "Stream feeding mode".
Resolution of AUTO & MANUAL mode
You can set the copy resolution used for AUTO and MANUAL ( ) exposure
mode.
on Mar 14, 2010 | Office Equipment & Supplies
How do i fix the error code sc 322 of my ricoh 3045 copy machine?
Have to open the Laser unit and clean the laser diodes carefully.
Dec 28, 2015 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Light copies in toshiba 230 photo copier
clean laser unit,and glass otherwise change developer and drum
Jul 14, 2014 | Toshiba E Studio 230 280 Copier
What is the service code
There is no service code.
To reset the copier press and hold 0,8. button and switch on the copier.
enter 690 press start button
enter 2 and press enter key on touch screen.
once the reboot massage apears switch off the copier and switch on.
Mar 29, 2014 | Toshiba E-studio 230 Multifunction Copier
Sharp al 1631 need drum roller reset code
enter code 42 start 1 start.
(press C auto C auto 42 copy1 copy)
Apr 28, 2010 | Sharp AL 1631 Copier
Have a Toshiba 230 copier but would get it as printer
Sep 18, 2009 | Toshiba E-STUDIO 650 Copier
Receiving faxed
when the machine goes into energy save mode it will still receive faxes. (energy save is a low power mode the copier is still on and can accept faxes, print jobs and copy jobs)
however if the machine goes to auto shut off it will not.
(auto shut off will after a set amount of time turn the power switch on the copier to the off position and the copier can not be used until it is turned back on.)
you need to turn the copier off, hold down 0 & 8 and turn on then type in 206 press start, key in 20 press set then turn the copier off and back on. this will make sure that auto power off is not enabled.
i hope this helps you.
Jun 01, 2008 | Toshiba e-Studio 350 Copier
Toshiba 2030 copier machine
hi Shailesh,
i have never heard of a Toshiba 2030 is it a eStudio 230?
Apr 10, 2008 | Office Equipment & Supplies
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
