Question about Health & Beauty
How to clean the front headlight inside cover
4 Suggested Answers
  • 73 Answers
SOURCE: My front headlight covers are cloudy. I need to
Those are a sealed unit. usually once you open them up they won't reseal well and you will replace cloudiness for moisture build up. Most common to replace the whole headlight assembly as a unit. Ebay motors is a good place to find inexpensive headlight assemblies.
Posted on Mar 18, 2010
  • 524 Answers
SOURCE: How do I clean the inside of a 2003 mercedes benz
if you can get the clear part separated from the backing you can polish this clean. It takes a little bit of skill and concentration and patients but it is possible
Posted on Mar 19, 2010
airjer995
  • 5332 Answers
SOURCE: How do I remove the headlight cover to clean the
If there fogged from the inside you'll need new headlamp assemblies. If there fogged on the outside they can be restored. I do headlamp restorations all the time. The trick is to know if the problem is on the inside or outside. Also if the "fogging" is condensation than for sure they will need to be replaced.
Posted on Oct 02, 2010
How did I get inside headlights to clean. Looks like water mark inside. Does the cover just pop off or do I need to replace whole thing
the silver covering of a headlight reflector cannot be touched
if it is stained , going black, rusty etc ,the fix is a new head light assenbly
Oct 18, 2015 | Cars & Trucks
How do I get to and clean the inside of both headlamp glasses because my car failed the MOT because the inside of the headlamp units are very dirty. Not the reflector but the front plastic cover.
NORMALLY THE ISSUE IS WITH THE OUTSIDE OF THE PLASTIC COVER. THEY CAN BE CLEANED WITH HEADLIGHT CLEANING KITS FROM ANY PARTS STORE.IF THE PROBLEM IS REALLY ON THE INSIDE THEN REPLACEMENT IS NEEDED
Dec 18, 2014 | 2002 Hyundai Santa Fe
Clean inside housing headlight
Chances are, it's pitting on the outside of the lense, not the inside. The inside probably is clean UNLESS, the rubber boot covering the holes is missing. You'd have to pull the headlight out and off the truck and try and clean through the holes the bulbs go into.
Apr 11, 2014 | 2004 Chevrolet TrailBlazer
1994 dodge dakato slt 3.9 how to remove headlight cover and side marker benzel
There are screws in plain site to remove the chrome trim
No cables involved ,just headlamp adjustment screws
Mar 04, 2014 | 1994 Dodge Dakota Club Cab
LIGHTS, FRONT HEADLIGHT, HOW DO YA REPLACE WHEN BURNED OUT?
You have to take the engine cover off to expose the headlight cover. Then locate the black headlight cover located inside under hood at rear of headlight. Gently depress clip and pop open cover. The rear of the bulb housing will pop out when you turn and pull. Replace bulb and reverse actions to reinstall. Hope this helps.
Jun 22, 2013 | 2005 Kia Amanti
Remove headlight cover
The headlight cover is not really a cover...it is the assembly which needs to be removed completely from the car to access the bulb hole that is the only access to the interior surfaces of the assembly. Lots of screws and awkward positions to get it out. Best bet, leave it alone or pull the bulb socket and use very long q-tips to clean out moisture!
Jan 20, 2013 | 1997 Suzuki Esteem
The head light cover is cracked. I got a new headlight cover and a bulb but how do I install the new headlight cover?
pop the hood and look inside in front of engine obviously, should give ya more of an idea seeing the backs of the screws at least or maybe you have to do it from the inside and will see screws from there, might even be along the front edge where the hood locks down. maybe when the bulbs are out you see some mounting screws there as well. good luck
Sep 13, 2011 | Dodge Neon Cars & Trucks
My front headlight covers are cloudy. I need to clean them on the inside or replace them. How do I remove them?
Mar 18, 2010 | 1997 Dodge Ram 1500 Club Cab
Failed its mot because of headlamps how do i clean them on a toyota lucida
we use paint restoring compound like t cut makes ya headlights look like new!! jason GTMOTORS
Sep 19, 2009 | 1995 Toyota Previa
How can i remove the corolla 2004's headlight cover to clean them from inside?
You have to heat the original sealant using a blower/hair dryer and slowly pull the cover from the base of the headlight. After you clean the glass then you have to seal it again.
Jul 01, 2009 | 2005 Toyota Corolla
Health & Beauty Logo
62 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
