Question about Canon Office Equipment & Supplies
What settings do i put on my canon p29-d iv for it to read with 2 decimal places...thanks
  • Canon Master
  • 3,287 Answers
Hi Heidi,
Locate the slide switch with the following under it:
"+ 3 2 1 0 F"
Slide the tab so that the number of places to the right of the decimal point you want shown / printed is above the number - in your case it would be "2". You may also use the "+" setting, which is "add mode" for adding and subtracting 2 digit decimals - and is convenient for currency calculations. These two settings and "F" (floating) are detailed on Page 1 and 2 of the manual - that I have linked below for you:
http://www.canon-ebm.com.hk/download/manual/P29-D%20IV_P39-D%20IV/P29-P39-DIV%20English_P.pdf
Posted on May 13, 2015
SOURCE: how to change the decimal point
2nd
Format
Select a number from 0-9
Enter
2nd
Quit
Posted on Sep 16, 2008
SOURCE: decimal places
How many decimal places are in the answer of this problem? 3.7844236 times 456.93874513
Posted on Nov 10, 2008
SOURCE: I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
Posted on Apr 23, 2009
  • 3 Answers
SOURCE: Default decimal settings
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Posted on Jun 11, 2009
SOURCE: I cant change my decimal place Sharp Calculator model EL-531WH
Set up > TAB > then select how many numbers you want after the decimal place.
Posted on Jun 16, 2010
How do i configure this calcualtor to round to multiple decimals and not the 2 decimal places it defaults to?
Use the middle slide switch of the three between the display and the keyboard.
The far left position sets it to two decimals, the far right position displays all effective digits up to twelve, the inner positions allow you to specify the number of decimal digits.
If you need a manual, you can download one from the manufacturer's web site at
http://www.usa.canon.com/app/pdf/calculator/HS-1200TS.pdf
Jul 26, 2011 | Canon HS-1200TS Calculator
What is the default setting for the f cut 5/4 and the 4320 add 2 I don't know what to have these options set at thanks EW Seattle
The selector you are asking about is the "decimal selector". The result displayed/printed, will be in a format according to the position that you have selected as follows:
f = floating (the result will be in the number of decimal places that were entered on the keyboard
4= fixed 4 decimal places (x.0000)
3= fixed 3 decimal places (x.000)
2= fixed 2 decimal places (x.00)
0= fixed 0 decimal places (x)
add 2= (add mode*,fixed 2 places) ($.00)
Note* "ad mode" automatically enters the decimal place when entering the number on the keyboard. If you enter "123", the displayed ammount will be "1.23". If you enter "1", the display will read ".01". This is a useful setting when adding a list of numbers in a dollars/cents format, however, be careful, if entering a whole dollar ammount "three dollars" be sure to enter the decimal point, or enter the number as "300". If you don't, the result will be ".03", instead of the 3 dollars you intended.
May 20, 2011 | Royal 29307U Calculator
Sharp EL- M332 caluclator- have a 'O' along top line- can't seem to get rid of it- must have accidentally selected something. It is not showing any decimals.
Hold (C.CE) then whilst holding it press (M+) for approximately a second and it will move one place along in the three settings (F, 2 and 0) F shows full decimals, 2 shows 2 decimal places and 0 as yours is set to now round to the nearest whole number. I have just been sat at my desk trying to work this out as my calculator was too set to '0'. Took me reading the 'DEC DET' text with lines pointing at 'M+' and 'C.CE' to finally crack it!
Hope this helps.
Apr 04, 2011 | Sharp ELM332BBL Calculator
How can I change the setting to print total the decimals. It is rounded off to the nearest one hundred.
You need to set your decimal selection to full-floating if you expect any numbers to be more than 4 decimal places.
Each time you press the DEC key it changes the decimal selection. From F to 0, 2, 3, 4 and A in that order. F is "full floating" but appears as a blank on the screen. A is the "add-mode" for currency transactions. The "A" does show on the screen if this is your selection.
As soon as the letter for the number of decimal places you want ("F" is blank just before 0 decimals) appears on the screen you are "ready to go." Problem is, the decimal indicator numbers and letters are so tiny and screen is so difficult to read that under many lighting conditions your selections might be all but invisible. They are in the upper left side of the screen just to the right of the equally difficult to see multiplication and division rounding indicator "5/4." PS If the 5/4 does not appear on your screen then you have set the round-off function to not available.
Feb 26, 2011 | Canon P1-DHV Calculator
Decimal placing
Above the feed button is an area for controlling the decimal placement. By leaving the slider on +, you have to manually put the decimal in.
0 - Means no decimal will be placed.
1 - Put it one place to the end. Ex: 4132.5
2 - Will make it read 413.25
3 - Will be 41.325
And so on.
Jun 24, 2010 | Canon P170-DH Calculator
Jun 01, 2009 | Texas Instruments BA-II Plus Calculator
Decimal places
Jun 04, 2008 | Canon LS-100TS Calculator
SETTING UP THE DECIMAL ON NEW 210 TM
Set the +43210F switch to + (or 2).
On some models it is A43210F, then use A (or 2).
+ mode will let you enter numbers (monetary) without the decimal point and assumes cents; 2 mode will just round to 2 decimals, but you must enter the decimal.
May 05, 2008 | Office Equipment & Supplies
EL-1197PIII Sharp Calculator
move switch for decimal places to "add",or to number "2" for 2 fixed decimal places
Feb 28, 2008 | Canon LS-100TS Calculator
241 people viewed this question
old marine
old marine
