Question about DeLonghi Pinguino PAC-600T Air Conditioner
How to clean the headlamp plastic cover - DeLonghi Pinguino PAC-600T Air Conditioner
    New Friend:
  • 18 Answers
USE T,CUT AND IT SHOULD CLEAN UP OK
Posted on Apr 27, 2015
How do I get to and clean the inside of both headlamp glasses because my car failed the MOT because the inside of the headlamp units are very dirty. Not the reflector but the front plastic cover.
NORMALLY THE ISSUE IS WITH THE OUTSIDE OF THE PLASTIC COVER. THEY CAN BE CLEANED WITH HEADLIGHT CLEANING KITS FROM ANY PARTS STORE.IF THE PROBLEM IS REALLY ON THE INSIDE THEN REPLACEMENT IS NEEDED
Dec 18, 2014 | 2002 Hyundai Santa Fe
How do I replace the headlight assembly MN133516
The 2003 Outlander utilizes replaceable (9007) headlight bulbs. If you're looking to replace the bulb(s);
1. Raise the hood.
2. Remove the plastic cover at the rear of the headlamp assembly by rotating it counterclockwise, and pulling it off. This will allow access to the headlight bulb.
3. Twist the bulb socket counterclockwise in order to remove it from the headlamp assembly. Pull the old bulb out of the socket, and use a clean cloth to install the replacement bulb. Do not touch the glass of the new bulb.
4. Place the socket back into the assembly, and twist it clockwise. Reattach the plastic cover, and close the hood.
Are you needing DIY instructions for replacing the entire headlamp assembly? Left (driver) or Right (passenger)?
Jan 18, 2013 | 2003 Mitsubishi Outlander
Replace headlamps on 2000 mercury cougar.
Headlamps unscrew from back of headlamp bezzle. Turn counterclockwise to loosen. May have to remove plastic cover under hood in front of radiator, to geta at headlamps. These are bulbs that are plugged into plastic connectors once removed from bezzle. Be careful as not to touch new bulbs with bare hands during installation. Use cheap latex gloves. Oils from hands lessens bulb life.
Nov 23, 2012 | Cars & Trucks
I just bought the coleman Max mult-colored headlamp and i cant figure out how to put the three AAA batteries in
In the headstrap is a plastic 'key' that you use to remove the battery cover (opposite side of the headlamp from the switch). Once you remove the cover, you can shake the headlamp to let the battery cartridge slide out of the headlamp.
Pay close attention to which way the batteries go in--if you put a battery in the wrong way you can easily bend the springs inside!
Oct 26, 2010 | Coleman 3AAA LED Headlamp
I need to find the fuse location for the headlamps on a 1999 Audi 2.8 A4 Quattro? Can you help?
The fuses location for the headlamps on a 1999 Audi 2.8 A4 Quattro are:
F18 (10 A) - RH headlamp - high beam
F19 (10 A) - LH headlamp - high beam
F20 (10 A \ 15A) - RH headlamp - low beam, headlamp adjustment
F21 (10 A \ 15A) - LH headlamp - low beam, headlamp adjustment
For Audi A4 the fuse box is located on the left side of dashboard behind a plastic cover (for left hand steering wheel vehicle). On inner face of the plastic cover you will find the fuse diagram.
Sep 20, 2010 | 1999 Audi A4
How do I remove the plastic from the headlight assembly??
These headlamp housings are sealed and not meant to come apart. There is a headlamp polishing kit that is sold in most auto parts stores that is used with a low speed drill to polish the fog and glaze out of the plastic lens using 3 or 4 steps of fine gritted paper with a polishing compound to finish the job. If the housing has water in it or is very dirty inside there isn't a whole lot you can do to get that out of there short of replacing it. Hope this helps a bit!
Jun 25, 2010 | 2000 Chevrolet Impala
I'm looking for the fuse identifier for a dipped headlight on my A4.And any troubleshooting advice id welcome. Thanks.
First fuse on first row from left upper corner is Fuse Nr.20 = F20 (15A) - RH headlamp low beam, headlamp adjustment.
First fuse on second row from left upper corner is Fuse Nr.21 = F21 (15A) - LH headlamp low beam, headlamp adjustment.
Jan 24, 2010 | 2004 Audi A4
Failed its mot because of headlamps how do i clean them on a toyota lucida
we use paint restoring compound like t cut makes ya headlights look like new!! jason GTMOTORS
Sep 19, 2009 | 1995 Toyota Previa
How to replace the head lamp on a 1990 Saab 900?
STEP 1 The following steps were for a 99 95 but should apply to all cars with slight variations. Unlike with some other types of cars... the wiring to your burnt-out headlamp (not to the Head...light Assembly) is hidden. First, find the large dome-like black plastic cover on the back of the headlight assembly. Rotate it slightly to unlock, and it should fall away. STEP 2 Grasp the plastic connector that is now revealed, and wiggle it from side to side while pulling toward the rear of the car.
STEP 3 Depress the upper part of the metal restraining clip so that it can swing down and out of the way. STEP 4 Gently pull, or rotate and pull, the headlamp out of the headlight assembly. STEP 5 Being careful not to touch the glass on your new headlamp... (use a clean cloth)...grasp the lamp by the two metal tabs and gently insert it into the hole in the assembly. STEP 6 Replace the connector. STEP 7 Replace the black plastic cover, rotating slightly to lock. Check to make sure it is locked in place.
Aug 15, 2009 | 1986 Saab 900
Change headlamp on a 1999 chevrolet malibu
The headlamp assembly on each side comes out as a unit. Raise the hood. Remove black plastic cover that hides the assembly. This is done by prying up on the plastic tabs on the cover that hold them in place. (They look like inserts) Once you pull up on the center portion of tab, the whole fastener comes out. Once the cover is out of the way, you will see these square black (about an inch Sq.) horizonal plates of which are connected to ball like fixtures (ball and socket) you pull up on the plates which release the ball to come out of the socket. The headlight assembly will swing out at the top, then raise straight up once it clears top. The headlight bulbs will now be accessible. Turn light bulb socket (with the wiring) counterclockwise 1/4 turn to remove. replace bulb. wipe clean with paper towel or cloth before reinstalling, as acid from skin or other contaminates will destroy bulbs. reinstall in reverse.
Road
Please rate me so I know if I helped.
Dec 19, 2008 | 1999 Chevrolet Malibu
DeLonghi Pinguino PAC-600T Air Conditioner Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
