Question about Krups Coffee Makers & Espresso Machines
Machine is dead. Is there a fuse somewhere? Krups Espresseria.
Will not turn on. Display is dark.
  • Ole Rambech
    Ole Rambech Apr 28, 2015
    Keen was right, no easy acessible fuse. But there is a termofuse on top of the heating element. That was the problem in my case.
  • Krups Master
  • 1,267 Answers
There is no easily replaceable fuse unless you are from somewhere like the UK where they have a fuse in their giant wall plug on the end of the cable. Some of those Espresserias had a switch button fault where part of the button can break and the button will no longer activate the switch.
Posted on Apr 27, 2015
Krups Espresseria Automatic Premium machine repeatedly displays the following message "Filling of machine necessary".
You may find that whatever detects the water level is faulty. Normally there will be a magnet that floats in the side/back of the tank. If it's sitting on the bottom of the tank then try and shove something plastic between it and the bottom of the tank to lift it up. If that fixes it then you have a choice to leave it like that or buy a new tank.
Feb 08, 2017 | Krups Coffee Makers & Espresso Machines
ERROR CODE E09 TO EA82
There is a problem with the heating of the thermoblock, it will require dismantling to check.
Feb 24, 2015 | Krups EA8250001 Espresseria Full Automatic...
How to stopp the leaking under the watertank?
Normally solved by replacing the tank seal where the tank plugs in.
Aug 30, 2014 | Krups EA8250001 Espresseria Full Automatic...
What do I do when coffee beans not getting to grinder
They cannot "not get to" the grinder, the hopper is mounted directly above the grinding teeth. The grinder is probably blocked and you will need to remover the housings and take out the grinder for cleaning and inspection. Most common cause of grinder blockage is dampness inside the housings from a leak somewhere inside the machine.
Jul 21, 2014 | Krups EA8250001 Espresseria Full Automatic...
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
Krups Espresseria Automic XP7200 coffee machine
As this is an automatic espresso machine, I suspect that the cake container is where the "used" pucks of ground coffee drop into after your espresso is extracted. The container may not be fully seated in position. See if there is a door on the machine that the container may be hiding behind.
Good Luck.
-Steve
Sep 27, 2008 | Krups XP7230 Compact Super Automatic...
Krups xp7420 espresseria automatic
am o proare 01 la un espesor krups 7220/7240
May 11, 2008 | Krups Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
135 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
