Question about Video Game Consoles & Games
I spilled soda on my wii console and now the wii will have the red light but when I push it it goes on then off right away like the blue flashes for a second how to fix
  • 1,140 Answers
The soda short circuited the electronic parts and caused permanent damage. There is no home remedy to fix it. It must be taken in to a shop to be diagnosed and then repaired or buy a new wii console.
Posted on Apr 27, 2015
  • Anonymous Apr 28, 2015
    But the soda was only under it
SOURCE: wii fit balance board
You need to sync the balance board with the console. Instructions are in the manual. Sync button for board is in battery compartment and sync button for console is in panel under reset button.
Took a few tries for me, be carefule not to hold sync button on console down for longer than 10 seconds because it will deregister all wii remotes.
Posted on Dec 23, 2008
  • 11 Answers
SOURCE: Wii Console will not turn off.
try turning it off on the console and not with the controller. turning it off with controller turns it yellow. press and hold the power button on console for 5 seconds it should turn red.
Posted on Jun 30, 2009
SOURCE: wii remote
Hey did you try holding the red button where you put the batteries and holding the red button where you put the SD card all unit have an button so it can read the sensor from unit to controller....
Posted on Aug 05, 2009
JackHeath
  • 1049 Answers
SOURCE: Wii power problem!
You are not getting the correct voltage into the Wii, this can happen one of three ways. (1) The power converter you have is not converting the power correctly, (2) running on converters are not exactly matching the correct voltage and wattage has strained your power supply and damaged the Wii, or (3) the power supply itself just failed as a result of any number of normal electrical conditions.
Posted on Jun 09, 2010
Peter Fix
  • 187 Answers
SOURCE: I have a solid red
Hello there peter
If you have the red blinking light then you have the RED light of death AKA the RLOD.
The light is a warning sign to let you know something is wrong. I can give you the quick explanation, There are 2 chips on the motherboard inside the PS3, the GPU (graphics) and the CPU (brain), when playing the ps3 the solder heats up and when you finish playing it cools down, over time this will cause the soldering to crack and the chips to lose connection with the motherboard and you get the RLOD.
WHERE TO GO FROM HERE
Option 1 - Call Sony
In warranty the Price is Free, out of warranty the Price is $150, the whole process is 4-6 weeks
You can call Sony and they will collect the PS3, repair/replace, and deliver the PS3 back to you
Option 2 - Fix it your Self
You can use a PS3 fix manual to get this fixed easily and at home using household tools you probably already own.
Click Here For The PS3 Manual which has helped so many people like you.
Good luck
Best regards
Peter
Posted on Sep 22, 2011
My wii won't connect to the wii remotes - batteries have been changed
The wii motes and wii console may need to be re-synced. To do this, press the red button on the wii console which is located behind the front panel. The button is right next to the SD card slot.
Then turn on the wii motes so that the blue lights are blinking. Next, push the red button on the wii motes which is located behind the battery cover. This should sync the wii motes to the console.
Mar 05, 2011 | Nintendo Wii Console
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
My wii fit board wont switch the blue light flashes then goes off
Unplug the AC adapter on your console out of the Power cord then wait 15 min and plug it back again.Open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Fit and push the red button there.If this not help press and hold the red button on your Wii for 20 seconds.This will clear all synced Wii Remotes from the console.Then repeat the procedure again.In this case you need to SYNC your Wii Remote too.If this not help your Wii Fit may need service.
Nov 03, 2009 | Nintendo Wii Fit - Balance Board + Game...
Wii fit board - blue power light flashes then goes off and wont work. This is also happening to my parents one and we are both on our 2nd wii fit board each. Have reset red button but no joy - help please
Unplug the AC adapter from power cord then wait 10 min and plug it again.Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.Then push the red button again, then open the batteries cover on your
Wii Remote and push the red button there.After that push the red button on console one more time, then open the batteries cover on your Wii Fit and push red button there.If this not help may your wii fit need service.
Nov 02, 2009 | Nintendo Wii Fit for Wii
My board will not turn on blue light flashes and nothing at all
Open the front cover on your Wii and push the red button there, then open the batteries cover on your Wii fit and push the red button there.If this not help may your Wii fit need service.
Oct 20, 2009 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board will not turn on. when button is pressed blue light flashes then turns off, have just put in new batteries
Re sinc it.Open the front cover on your Wii and push the red button there, then open the batteries cover on your Wii fit and push the red button there.If this not help Open thre front cover on your Wii and push and hold the red button for 20 seconds.This will clear all sync devices.Now try again to sinc Wii fit.In this case you need to sinc your WII Remote/s again too.If and this not help may your Wii fit need service.
Oct 19, 2009 | Nintendo Wii Fit - Balance Board + Game...
Can't sync wii remotes to console
When you sync the wii motes you have to do it in proper order!!!
There are 2 ways to sync one is minor out of sync stuff. You push red button on the wii briefly then quickly press the red button on the wiimote.
Second one is what you need to do. First remove any disk then hold in the power button until the light turns red. (not yellow or orange). Release it then unplug the Wii. Do not remove the batteries but if they are low replace them before you turn it back on. Wait at least 2 minutes.
Have the backs off the Wiimotes.
Plug the Wii in.
Turn the power on.
As the Health and Safety screen appears push in the red button on the Wii.
Hold it there a min. of 15 seconds. 25-30 is better.
When you release it right away push the red button on the first Wii mote. It flashes all the lights.
Immediately press then release the red button on the Wiimote while lights are flashing. When they stop flashing it will be synched.
a.Then press the button on the Wii again (this time only hold for 2-3 seconds) then press the red button on the second wiimote and while lights flash press the button on the Wii again.
Repeat a. for any other wiimotes.
Jan 01, 2009 | Nintendo Wii Console
How do i program a wii controller
Under battery cover on wii remote is a little red button. Under disc slot is a little flap where sd card goes in, next to this is a red square button. Press both red buttons at same time for 5 secs. Blue lights on wii remote will flash and everything will be fine.
Dec 02, 2008 | Nintendo Wii Console
New wii remote
Maybee you shou hold the red button?
Nov 08, 2008 | Nintendo Wii Console
Power
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
Video Game Consoles & Games Logo
143 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
