Question about In Microwave Ovens
I have a west bend 0.9-cu ft 900-wave microwave that paint in killing bubbling up
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
sharcnet
  • 2130 Answers
SOURCE: paint peeling inside microwave
If the unit has been operating properly for some time with no issues, I would say it is fine to continue to use. The issue I would have would be with the possibility with the paint falling into the food.
It would be interesting for you to call the manufacturers' support line and ask why this is happening. Maybe they will offer you a replacement if it was a manufacturing process defect. Mention that the paint may have fallen into the food.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 13, 2008
carputers
  • 255 Answers
SOURCE: my microwave keeps beeping several times and i put
it junk replace it befor it burns u house down
Posted on Sep 07, 2009
  • 949 Answers
SOURCE: Was cleaning inside of microwave and noticed the
Hi Bonnie,
Do not use the microwave with the exposed metal surface.
What you can do is pick up some appliance touch up paint, it comes in a small plastic bottle with a brush. It looks similar to fingernail polish. It should be available at an appliance store such as Sears, Lowes, Home Depot etc.
Clean the area good and use sandpaper or steel wool if needed to make sure the area is smooth and clean. Then use the touch up paint to recoat the surface. Let dry before using the microwave oven, usually a couple hours or so.
Posted on May 01, 2010
Testimonial: "Many thanks for such a quick reply and solution. Bonnie"
MicrowaveSvc
  • 9098 Answers
SOURCE: Paint has bubbled and chipped off in microwave
Apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Aug 19, 2010
How do you set the power level
If you have a power level button---press it and then enter 1-0 for 10. Most microwaves automatically come on at power level 10 or Hi power unless you pick a different option like the defrost button which is usually power level 3.
Mar 31, 2015 | Westbend 0.9-cu. Ft. 900-watt Microwave -...
My microwave oven siows down and then speeds up.
Is it still heating food properly? You can perform a basic test with a microwave safe mug or plastic cup of water. It should be boiling or too hot to touch within 1 to 2 minutes. Be careful not to overheat the cup if plastic and use extreme caution when touching or removing it from the microwave.
If it is not heating properly then the magnetron may be faulty and unit should be replaced.
Can you tell what specifically is speeding and slowing? Is it the turntable or the humming sound of the unit itself? Many microwaves vary their intensity in order to heat/cook evenly and that will vary the pitch of the sound you hear and sound like it is speeding up or slowing down. If the turntable is slowing and speeding up then there may be a bad motor and the unit should probably be replaced.
If the unit is heating adequately and the turntable speed is uniform then what you may be hearing is simple power cycling and/or fan noise.
Only trained and certified technicians should attempt repair of microwaves due to the hazards of high voltage and microwave radiation leakage if parts are not replaced properly. Although you can have a microwave repaired the cost may be equal to, or higher than, the cost of an equivalent new unit for a 900w microwave.
Feb 28, 2015 | West Bend 0.9-cu. Ft. 900-watt Microwave -...
There is rust inside the microwave, ist it still safe to use
if the unit starts to spark then you can buy microwave paint but if it goes through the door or the base then a professonal repair is best,clean the rust with rubbing paper and coat with thin layers let each one dry and build up a good layer of paint,hope this helps.
Dec 11, 2012 | Goldstar Gold Star Er710m 1.35 Cu Ft...
What is the size of Haier 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK?
The of the Haier 700 WATT MICROWAVE TOUCH 0 7 CU FTBLK is 17" W x 10 3/16" H x 12 7/8" D.
Jul 15, 2012 | Haier MICROWAVE TOUCH
How much does the 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK weigh?
The Haier 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK weighs33.1 lbs (15 kg)
How many power levels does the 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK have
The 700 WATT MICROWAVE TOUCH 0 7 CU FT BLK has 10 powerlevels with electronic touch controls.
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
May 10, 2010 | Emerson MW8675W Microwave Oven
General electrics microwaves
If it is a counter-top model, I would guess between 700 and 900 MHz.
With the size of the model (in cu. ft.) and the model number, I could more definitively answer your question.
My microwave is also from that era, though not GE.. however, the MHz is clearly labeled on the inside my microwave, not on the back. If you haven't already, look for such a label inside yours.
If there's any more I can help you with, let me know.
~Alkara
Mar 10, 2008 | Microwave Ovens
Microwave Ovens Logo
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
