The arm plays for a few seconds then returns to the cradle
Is it a faulty switch
    Sergeant:
  • 357 Answers
On which make and model turntable?
Posted on Feb 23, 2016
4 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: the arm will not return to stationary and the table keeps spinning afer the record is played
HI...
One or two mechanical linkages inside have "let go"
Denon is good stuff. Depending on where you live I might be able to suggest someone to fix it.
Posted on Jan 19, 2009
SOURCE: turns off
I had the exact same problem for a while, but was able to fix it. I somehow disabled and turned off the stopping sequence completely by lifting the platter, and rotating the plastic cog counter clockwise to it's limit. Somehow this odd solution worked great. Though I sacrificed the stop sequence, it saved me money buying another one and also the extreme annoyance of the dysfunctional arm.
Posted on Aug 15, 2009
  • 8 Answers
SOURCE: I've recently picked up a Pioneer Plx-88z
Check the auto trip lever which should return the arm back to it's rest after the end of the record.It has possibly been advanced.Is this a belt frive or direct drive turntable?
Posted on Jun 06, 2014
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
I've recently picked up a Pioneer Plx-88z turntable second hand. I know that the player is working ok as putting the arm on the record plays music. The problem is that after a few seconds, no matter what,...
Hi, if it's a second hand device. there must be something wrong with the arm at it's moving axe. if something (dust or broken support) is blocking it, it will return automatically to its rest position to avoid any damage to the fragile and sensible "head"
Jun 02, 2014 | Audio Players & Recorders
I taking out my HP deskjet 3050 j610a out of the box as i have newly bought it. As i try to get the alignment page printed the screen just says printing and nothing happens. Then i switch it off and back...
This printer appears to be faulty, I suggest you return the printer to the supplier for a replacement or repair as it is under warranty. If you try to repair it yourself, you most likely void your warranty.
Aug 24, 2011 | HP LaserJet 3050 All-In-One Printer
I have a Realistic LAB 2100 Linear Tracking Automatic Turntable. When the arm is drawn closer to the center of the record, the motor that is supposed to move the arm into a perpendicular position with the...
It seems like you need to adjust the pitch control. Try looking at the platter strobe light and seeing if it is at the correct speed. If not adjust the pitch control until you can see the dots align. As for the not returning, your automatic motor may be busted.
May 15, 2011 | Radio Shack Audio Players & Recorders
Tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Audio Technica AT-PL50 Turntable
Sony pslx250h
Did the problem exist on its own uncorrelated to anything you may have done?
Does it return and cycle itself off or is it just rebounding aimlessly?
Unfortunately, there are no user adjustments for tracking, antiskate, end-of-play-return, etc. The only recommendation from the manual is to make sure the turntable is level and the records are clean and unscratched.
Mar 19, 2009 | Sony PS-LX250H Turntable
My prolectrix usb turntable won't play properly
i also have the same problem, im sure its something to do with the tone arm, like at the start of playing a 12'inch you have to hold the arm at the end of the vinyl for 5 seconds, have i answered my own question, i'll let u know ......
Jan 06, 2009 | Audio Players & Recorders
The arm will not return to stationary and the table keeps spinning afer the record is played
HI...
Apr 01, 2008 | Denon DP-47F Turntable
198 people viewed this question
 Grubhead
Grubhead
