IT PLAYS FOR A FEW SECONDS THEN THE ARM RETURN TO THE CRADLE
IS IT A FAULTY SWITCH
    Top Expert:
  • 10,875 Answers
Needs adjustment
Posted on Apr 27, 2015
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
I've recently picked up a Pioneer Plx-88z turntable second hand. I know that the player is working ok as putting the arm on the record plays music. The problem is that after a few seconds, no matter what,...
Hi, if it's a second hand device. there must be something wrong with the arm at it's moving axe. if something (dust or broken support) is blocking it, it will return automatically to its rest position to avoid any damage to the fragile and sensible "head"
Jun 02, 2014 | Audio Players & Recorders
Need to know how to replace lower control arm
LOWER CONTROL ARM
REMOVAL
1) Raise and support vehicle. 3) Remove the steering knuckle.
Remove the bolts fastening the power steering cooler to the front suspension cradle crossmember reinforcement (Fig. 21). 5) Remove the lower control arm rear bushing retainer bolts located on each side of each lower control arm rear bushing. NOTE: The bolts fastening the cradle crossmember reinforcement are of three different thread sizes. Note the location of the various sizes.
6) Remove the bolts attaching the cradle crossmember reinforcement to the front suspension cradle crossmember (Fig. 22). Remove the 2 bolts fastening the reinforcement and rear of cradle crossmember to the body of the vehicle. Remove the reinforcement. 7) Remove the pivot bolt attaching the front bushing of the lower control arm to the front suspension cradle crossmember. 8) Remove the lower control arm.
Sep 25, 2009 | 2006 Dodge Caravan
Tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Audio Technica AT-PL50 Turntable
Car Cassette Adapter keeps flipping from one side to another
This is a faulty firmware problem in the player. It may have a faulty internal capacitor that is screwing up the player. You can use a capacitor tester to find faulty capacitor or replace with a cd player
Aug 24, 2009 | Alpine TDM-7561 Cassette Player
The arm will not return to stationary and the table keeps spinning afer the record is played
HI...
One or two mechanical linkages inside have "let go"
Denon is good stuff. Depending on where you live I might be able to suggest someone to fix it.
Apr 01, 2008 | Denon DP-47F Turntable
Mitac mio 168 non charging problem
I sent my battery back and it was replaced by the supplier. The unit is fine now so the only conclusion I can come to is that it is due to a faulty battery....
Jan 18, 2008 | Mitac Mio 168 Pocket PC
150 people viewed this question
 Grubhead
Grubhead
