Question about Craftsman Vacuums
,I took apart my Craftsman 16 gallon double insulated wet dry vac to. 2.Peak power wet dry vac and I don't know the wiring for the 4 wires to come off the motor from the brushes to the switch
    Problem Solver:
  • 7 Answers
Is it a Single motor ?
photos would be helpful - of switch
& motor/cap. wire conn.
Posted on May 12, 2015
Curt_W
  • 60 Answers
SOURCE: husky 6 gallon dry/vac wont **** in air, only blows air out
Maybe you have the vac hose plugged into the blow out port.
Posted on Nov 16, 2008
SOURCE: Can't install a bag for my Craftsman 16 gallon shop-vac
Well, good news, you don't need a bag! The trash just settles to the bottom of the bucket and you just dump it out.
I own one of these -- it has many little operational anoyances -- like wheels falling off, lid popping off, etc. If you run into these scenarios and want help on fixes, drop me a line.
Would you please rate my response. I think you'll see some icons at the bottom of the post to enter a rating.
thanks...
Charlie
Posted on May 09, 2009
  • 206 Answers
SOURCE: I had a loose wire in my Oreck XL motor. I took it
Lights are 12 volts.
The motor has taps on it to pull 12 volts rather than 120 volts for the lights, uses the motor as a transformer.
Should be black and white to the motor from the switch, believe the switch breaks the black wire. White wire should be neutral. I can't remember colors for the wires to the lights. Would expect it to be the white wire and then the "tap" wire to be red.
One crazy way to do it, is to hook up wires, leave the light bulbs out, turn on power, and check voltage at the bulb socket with a voltmeter. (This is one of those things they tell you on television to only let a professional do, do not attempt at home.)
Posted on Aug 07, 2009
SOURCE: Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Posted on Sep 09, 2009
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
I need a manual for a Sop-vac 1.5 gallon.
Have a look at this page and if it matches your product, you can click "user manual" on the right hand side to download a PDF version of the manual.
Shop Vac 1 5 Gallon 2 0 Peak HP All Around EZ Wet Dry Vac
Sep 19, 2017 | Vacuums
I ran over the cord to the vac with my lawn mower ,I need to replace the damaged cord with a new one. How do I remove the old cord?
You need to remove the screws that are in the location of where the wire goes into the vacuum. Then you will see a cord grip and connectors for the wires.
May 13, 2016 | Craftsman 2.5 gal, 1.75 Peak HP Portable...
How to replace the power cord?
Follow cord to where it goes on mower, then connect the wires the same way you took them off. but be sure to turn power off!!
What is 700a shop vac motor size
Craftsman 17765 canister vacuum cleaner is known for its assortment of power tools especially when it comes to cleaning jobs. It is designed to give you an easier, more effective cleaning. This vacuum cleaner delivers a high capacity reservoir, power and the versatility to swap easily between tasks. Craftsman wet/dry vaccums soaks even drosp of water on the floor with one of their 16 gallon wet/dry vacuum. It is also equipped with utility nozzle, extension wands, and dust bag that makes the cleaning process easier. The extension wands can clean the hard to reach areas like cupboards, corners, and bends. It has a large gallon tank that includes convenient drain port for easy emptying when the job is done.
Number of Tools:
Attachment Type:
Brush
Details and Capabilities
Cord Length:
Tank / Bag Capacity:
12 Gallons
Weight:
Hose Reach:
Cleaning Areas:
Car
Electricity
Horsepower:
5 HP
Voltage:
110 - 120 V AC
Power Consumption:
1210 Watts
Jul 09, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
How do you replace the switch on a shop vac 2.0 quiet series
The switch should be connected to the power cord just use a multimeter to work out where the wires go , do you have a pic of the switch ?
Jun 25, 2014 | Shop-Vac Products 5-gallon 2 0-peak Hp Wet...
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
I need to replace a brush to operate the shop vac. Where can I find it?
true value hardware stores have books to order these parts , piar of brushes are between $3 -$7 ,also most vaccume sweeper shop
Jul 13, 2009 | Craftsman 9-17765 12 Gallon Wet/Dry Vac,...
How do i turn the pump on to pump out the water this is a 16 gallon 5.75 peak horsepower wet dry vacuum.
If you want to get water that's in your vacuum, OUT of your vacuum, you simply need to remove the top and dump the water out. As far as I know, the Shop-Vac 962-16-00 won't "pump out" any water that's in it.
If you want to pump water from one place to another (for example, your basement to your backyard), this vacuum doesn't pump water "through" itself (like a sump pump) - it will, however, **** water up. You just need to dump it out once the vacuum is full.
Jul 08, 2009 | Shop Vac 962-16-00 Ultra Pro Canister...
Vacuums Logo
137 people viewed this question
Top Craftsman Vacuums Experts
downhille
Vernon Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
