Question about Nikon D3200 24.2 MP CMOS Digital SLR with 18-55mm f/3.5-5.6 AF-S DX VR NIKKOR Zoom Lens
In memory slot by mistake i had inserted small memory card i shall take it out
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 33 Answers
Yes , use only compatable memory card.. of your are unable to take it out , it's better to take it to a service center. You can use a plastic paper cut it in shape of the slot a bit longer in size. Place it within the slot and try to pull it out.
Posted on May 12, 2015
My memory card damage inside the nokia 5130 as i insert in wrong slot what shall i do for this .....
Hello once a memory card is damage/broken we could not repair.Because the chip inside the memory card can broke easily.So, my comment is to buy new one.Thanks for visiting fixya
Jul 19, 2012 | Nokia 5130 Cellular Phone
Show your memory card location
Remove the back cover by holding the phone firmly then slide in the back cover of the handset. You will now see your MicroSD and SIM card slots. Take your SIM card and slide it into the slot provided with the chip facing down. You will also see a small diagram showing you which way to insert the SIM card. Now slide open your MicroSD memory card slot gate, pop your MicroSD memory card into the slot, then close the MicroSD memory card slot gate by sliding it forward then backwards.
Oct 29, 2011 | LG GD510 Cell Phone
I put my psp memory card into the sd slot and now it wont come out wht shall i do?
Try using tweezers or very small needle nose pliers to get your memory stick pro duo out of the SD slot.
Mar 14, 2011 | Computers & Internet
I have a sandisc memory stick pro duo 4gb and it is too small to fit in the memory card slot of my laptop which is an acer aspire 7220 series. please help x
Hi there!
Simply insert the card in it's adapter, then insert it into the memory slot.
However you can buy yourself an external USB card Reader supporting your pro duo card.
Please rate this advice as it's very important for us.
Good luck friend!
Mar 13, 2010 | SanDisk 2GB Memory Stick PRO Duo Memory...
PNY 2GB cell phone memory card does not seem to fit into the slot in my LG phone
Have you tried to insert it the upside down? Try it. You may be inserting it the other way round. So try both ways and one of them is bound to work. LG can not make such a mistake as to make the slot different for the card.
Dec 02, 2009 | PNY 2GB microSD Memory Card
Memory card will not push in and stay engaged in memory card slot
This happens most of the time with digital camera and mobile phones, if you try to insert the memory card in a wrong direction. Before inserting your memory card, look into the slot hole and see the position of contact terminals and insert your card in such way that the card comes with contact with the terminals inside the slot. If your card already got struck into the slot, try removing it by pulling out using a small nose plier. Also try with another memory card of similar type to detect any problem due to your memory card. I hope this will help you out.
Aug 04, 2009 | Canon PowerShot A720 IS Digital Camera
Micro M2 memory card adapter
Memory stick flash memory is tricky. If it is too small, DO NOT INSERT IT. I made this mistake and was lucky enough to have some tools handy to get it back out. You'll need a different adapter to use it in the memory card reader that you have.
As for "guest" 's conundrum. You will need to use either needle nose pliers or tweezers to VERY CAREFULLY remove it. It won't be easy and you have to be careful so as not to push it farther in (which eventually it will stop going in, but still makes it that much harder to get it out)
Good luck
Jan 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Cannot insert the memory card - push in, won't seat, springy feel
Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
Doug
Nov 03, 2008 | Canon PowerShot A720 IS Digital Camera
Small memory card stucked inside SD memory card hole
vijju_rasala hello,
Please go to the following address, and insert your model number. There you can find specific instructions on how to open your laptop properly.
http://www-307.ibm.com/pc/support/site.wss/product.do?doctypeind=8&template=%2Fproductselection%2Flandingpages%2FonlinePublicationsLandingPage.vm&sitestyle=lenovo
Sep 08, 2008 | Lenovo 3000 Y410 Notebook
Have a dell Inspiron 1525 notebook with memory card reader, compatible with Memory Stick Pro - but i cannot figure out how to insert the memory stick into the memory card reader - an SD card slots in...
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
Aug 18, 2008 | Computers & Internet
Nikon D3200 24.2 MP CMOS Digital SLR with 18-55mm f/3.5-5.6 AF-S DX VR NIKKOR Zoom Lens Logo
320 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
