Question about Garden
Kohler courage 20 someone turn the screw on the government and I cannot get it to idle down?
I do not know where the screw on the governor was setting. What do I do to get it to idle down? I have to explain to someone because I am paralyzed and I cannot use my hands. I just you know what to do, thank you
  • 109 Answers
SOURCE: Sears lawn tractor-25 horse Kohler engine-revs won't slow down!
The governor will need to be replaced
Posted on Apr 24, 2009
SOURCE: DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
Posted on Jul 26, 2009
  • 62 Answers
SOURCE: governor shaft doesn,t react to engine speed,
THE GOVERNOR GEAR MY BE SHOT IN THE ENGINE
Posted on Sep 25, 2009
huffman49
  • 235 Answers
SOURCE: MY NEIGHBOR KOHLER COURAGE 20 LTX1045 WILL TURN
check and see if it's getting spark by removing the plug from the engine and keeping it plugged into the wire,lay the plug on the head and turn the engine over and look to see if the spark is jumping accross the gap. if it's blue your ok if it yellow you'll have to replace ignition modual..good luck
Posted on Apr 10, 2010
  • 4 Answers
SOURCE: Governor hunts
Pour vinigar and hot pepper sparkles into the gas tank and mix it with the gas. Then start it- the differance in the way it runs will be very noticable!
Posted on May 31, 2010
Locate and change engine governor kohler 18 hp courage engine
To access the governor you need to remove the flywheel, undo all the closure plate bolts and remove the crankcase closure plate, all this can be done with the engine still on the tractor, the governor is a plastic gear with centrifugal weights driven via a gear on the crank, it works against an arm that runs through the side of the crankcase and connects to a lever that then goes to the carb, to reset the lever, slacken the locking screw, push the governor lever fully over so as to open the throttle fully, now with a pair of pliers rotate the centre shaft fully in the same direction as you have pushed the governor lever, then tighten the locking screw
Jun 03, 2018 | HP Garden
How do I adjust the governor on a 2009 Kohler Courage 20 HP engine?
loosen the pinch nut for the gov arm. have throttle at full. rotate the gov shaft in the same direction that the arm is for full throttle and tighten the pinch bolt.
Jun 06, 2016 | Garden
The egine runs to fast wih a touch the throttle,what causes that/
does the engine idle when throttling down,if not you may have a worn governor or incorrect spring and or linkage settings.
Apr 22, 2016 | Kohler 20 Hp OHV Command V-Twin Engine...
Can't idle back
Sounds like the governor is stuck. Look at the linkage as it passes through the top of the carburetor. rotate it and see that it is moving freely
Dec 08, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro 52" deck with 19hp kawasaki engine runs fine when not under a load, when blades are engaged the throttle constantly goes up and down. I am assuming it is a governor problem, and have made sure the...
Could also be a carburetor issue, remove air filter and make sure that its not clogged, even try running it for a short time under the same load. If problem persist tske it to rdpair shop bc there are several other issues it could
Aug 19, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Do you not know how to reset governor
go to youtube they have videos on how to adjust governor
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Governor hunts
May 22, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Apr 10, 2010 | Garden
Jul 03, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
