Question about Garden
I just put new wiring harness in and it wont start it will if I take the regulator cover off and press on the battery connection it starts right up do I need to replace the regulator
  • 1,835 Answers
Sounds like it could be a loose or dirty battery connection. Check this out before you go farther..
Posted on May 03, 2015
Why alternator don't charge on a 1979 ford thunderbird?
If you can use a new wire and they charge the battery then most likely you have a broken wire in the harness that runs between the alternator and the regulator.
Jun 10, 2017 | Ford Thunderbird Cars & Trucks
How do i replace a crankshaf position senor on 2000 trailbazer/chevy
Should be a wiring harness and a one or two bolts holding the sensor right onto the block. Remove negative battery cable, undo wiring harness, take out bolt(s) and remove the sensor. Pull it straight out, do not bend or snap the sensor off inside the motor.. Put the new one in, and bolt up, connect the harness and the battery. Let key sit in "ON" position for about a minute before first start then start and let run for a couple minutes before driving. Good Luck!
Feb 16, 2015 | 2000 Chevrolet Blazer
1990 dr 250s(street) switching back to dirt only. what electrical do I have to leave on the bike for it to start. I have removed lights and horn. Removing the wiring harness and battery.
At a a minimum, you will need the magneto (inside left engine cover), the regulator/rectifier (right side, under seat -- has fins on it), the CDI (under seat, at front of airbox), and enough wiring harness to connect the 3. You should put a large capacitor in place of the battery. You will need to jump the sidestand and clutch safety switches, as removing them will cause a no-start condition.
Dec 01, 2014 | Motorcycles
Wont start with new battery
Check the connections at the starter motor. You may have a problem with the ignition wire there.
Aug 24, 2014 | Cars & Trucks
Ttr 230 wont start with new battery
Hi, Grant the following is a comprehensive charging system test that is guaranteed to the find issue with your system.
1. Battery Test: The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Check Connections/Wires: Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator
Start motorcycle and change Voltmeter to AC volts.
Probe both stator wires with your meter lead.
The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale.
Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on system, check service manual for specification
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
Stator IB test or Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire.
The reading should be Infinite.
With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
My TTR230 won start plz help
What to Do Check When Dirt Bike Won Start
Yamaha ttr230 Service Manual
OEM parts for Yamaha
Yamaha TT R230 Owner Manual
Jun 18, 2012 | 2010 Yamaha TTR230
How to replace head gasket on 4 cylander
2.6L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Drain the cooling system.
  3. Relieve the fuel system pressure.
  4. Remove or disconnect the following:
    • Negative battery cable
    • Hood
    • Accessory drive belts
    • Accelerator cable
    • Positive Crankcase Ventilation (PCV) valve and hose
    • Air intake duct
    • Fuel pressure regulator vacuum line
    • Canister hose
    • Brake booster vacuum line
    • Engine wiring harness connectors at right wheel housing
    • Ground cable connector at the intake manifold, starter and firewall
    • Heated Oxygen (HO2S) sensor connector
    • Alternator wiring connectors
    • Oil pressure switch connector
    • Starter motor harness connectors
    • Ignition coil connector
    • Spark plug wires
    • Distributor
    • Exhaust front pipe
    • Exhaust Gas Recirculation (EGR) gas temperature sensor connector
    • Air pump
    • EGR pipe
    • Heat shield
    • Exhaust manifold
    • Throttle Position (TP) switch connector
    • Cooling fan
    • Water pump pulley
    • Power steering pump
    • Intake manifold
    • Crankshaft pulley
    • Front cover
    • Timing belt. Refer to the Timing Belt unit repair section.
    • Valve cover
    • Rocker arms
    • Camshaft
    • Cylinder head
Cylinder head bolt loosening sequence - 2.6L engine
  1. To install:
  2. NOTE: Refer to Section 1 of this manual for the cylinder head torque sequence illustration. The illustration is located after the Torque Specification Chart.
  3. NOTE: Lubricate the cylinder head bolts with clean engine oil for assembly.
  4. Install the cylinder head with a new gasket. Tighten the bolts in sequence as follows:
  5. Step 1: 58 ft. lbs. (75 Nm)
  6. Step 2: 72 ft. lbs. (98 Nm)
    1. Install or connect the following:
    2. Camshaft
    • Rocker arms
    • Valve cover
    • Timing belt
    • Front cover
    • Crankshaft pulley. Tighten the bolt to 87 ft. lbs. (128 Nm).
    • Intake manifold
    • Water pump pulley
    • Cooling fan
    • TP switch connector
    • Exhaust manifold
    • Heat shield
    • EGR pipe
    • Air pump
    • EGR gas temperature sensor connector
    • Distributor
    • Spark plug wires
    • HO2S sensor connector
    • Canister hose
    • Air intake duct
    • PCV valve and hose
    • Accelerator cable
    • Hood
    1. Fill the cooling system.
    2. Start the engine and check for leaks.
    Feb 05, 2011 | 1997 Isuzu Rodeo
    My 1987 Kawasaki is losing it's charge! new battery keeps dying
    FIRST OFF, EVEN THOUGH THE BATTERY IS NEW TO YOU, IT MAY HAVE BEEN ON THE SHELF AT THE DEALER FOR SOME TIIME. VERIFY A GOOD BATTERY WITH THE APPROPRIATE TESTER. AFTER THAT YOU CAN CHECK YOUR STATOR BY VERIFYING CONTINUITY AND OPENS IN THE STATOR HARNESS. EASIER WAY IS TO DISCONNECT THE BATTERY AFTER YOU START THE BIKE AND IF IT CONTINUES TO RUN THE STATOR IS LIKELY OK. AND YOU SHOULD LOOK AT THE REG/RECT AT THAT POINT. YOU'LL NEED CORRECT MEASUREMENTS FOR THE READOUTS ON THESE TESTS. QUICK CHECK THE STATOR BY TESTING ACROSS THE 3 YELLOW LEADS. YOU SHOULD GET CONT. WITH ANY COMBINATION OF THE THREE WIRES. NOW TEST EASH YELLOW LEAD TO GROUND. THERE SHOULD BE "NO" CONT. BETWEEN ANY YELLOW AND GROUND. IF THERE IS, IT IS SHORTED AND WILL NEED REPLACING.
    ON A BIKE OF THIS AGE IT ISNT UNUSUAL FOR THE STARTER BUTTON TO "RESIST" SOMETIMES. THIS IS IN THE PSUH BUTTON ITSELF.SOMETIMES YOU CAN REPAIR THESE CONTACTS AND SOMETIMES YOU CANT. IF IT CLICKS WHEN YOU PRESS THE START BUTTON, THAT COULD BE THE START RELAY OR A BAD WIRE CONNECTION. CHECK THESE ALSO WHEN YOU CHECK YOUR BATTERY!
    Oct 22, 2009 | 1986 kawasaki ZL 900 A2 Eliminator
    My 95 f3 will crank but wont start. everything was working fine replace a headlight now it wont start with the starter. battery is charged and i can push start it but the engine just cranks and cranks and...
    Sounds like a wire or plug got disconnected while changing the headlight out, the harness that connects to the clutch safety switch, the one that lets the ignition fire when cranking only when the clutch is pulled in. A safety feature so you don't dump the bike if you crank it while in gear.
    Sep 12, 2009 | 1997 Honda CBR 600 F(3)V
    Truck wont start, new battery, good fuses, bench tested starter they say its good, cables look ok.Turn ignition and dash lights come on can hear fan motor running.
    test starter solinoid wire from harness, with a helper put test light on wire get friend to turn key to start, light should light up, wires at the bottom of engine may (look) fine
    Apr 25, 2009 | 1989 Chevrolet C1500
    1997 chevy 1500 wont stay runing
    Ok, first, you need a new altemator. When you pulled off the battery cable with the truck running . it caused a voltage spike and fried the voltage regulator, which is internal on this particular altenator. If you want to check to see if the altenator is charging, use a volt meter.
    Since it wouldn't start after you put the new altenator on, it could be one of two things, either you got a bad altenator which happens sometimes or, you have a weak battery and the altenator is tryng to charge itself to death.
    Apr 10, 2009 | 1999 Chevrolet Silverado 1500
    Garden Logo
    51 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
