Question about Connex Radio Communications
My connex 4400 has drop down a channel it transmit on 19 but to receive u have to turn it down to 18 can it be fixed
    Genius:
  • Connex Master
  • 1,795 Answers
Yes but you will have to take it to a tech and let him do it because of process to do the repair.
Posted on Jun 18, 2015
  • 125 Answers
SOURCE: connex 4600 turbo
It is lkikely that you burn the output transistors. You can easily check these transistors even if it is soldered but be aware of low resistance paths like coil , toroid, and lo ohm resistor which might affect the reading in the multitester. To be sure desolder at least 2 pins before testing. I do not think that the driver is damaged.
Posted on May 22, 2007
  • 83 Answers
yup you fried the finals
Posted on May 31, 2007
thetez
  • 32 Answers
SOURCE: My superstar 3900 transmits on one channel and receives on one ch
Ok! well i deffinitally know what the problem is. You need to play with the clarifier, i think all the way to the left is a "course and fine tune" knob. This is generally for use when talking on SSB. but may affect AM if its way off.
The clarifier lets you slide on the freq. some radios will go a full channel some will only go a little or above the center of the channel. You need to play with the clarifier, you probably need to turn the course a lot, untill the audio is almost clear on the channel you want to talk on, than use the fine to tune it in so it sounds like they are sitting right next to you.
what you should do is buy a Frequency counter, you got a nice radio, so the freq. counter wouldent hurt. lets say you want to be on channel 19. you would turn the clarifiers untill i read 27.1850 That would put you right on the money
Posted on Jan 13, 2009
Benimur
  • 6966 Answers
SOURCE: Radio lights up, but no TX/RX.
Hi and welcome to FixYa,
Based on your description, a possible drift in the local oscillator.  Check the 10.24Mhz crystal filter and its local oscillator for output and consistency.
Good luck and thank you for asking FixYa.
Posted on Aug 24, 2009
  • 1274 Answers
SOURCE: Knob setting of front of radio (Connex 3300)
The best way to set it is to get you a radio check, go to channel 19 and ask someone about three to five miles away to give you a radio check, start with your modulation all the way open and go from there.....hope this was helpful...
Posted on Apr 20, 2010
How do I convert my connex 4400 turbo from 10 meter to regular cb channel. I have the module to do so, but not sure what to do with it.
Your connex should have a know with letters on it A,B,C,D,E,F, Look at the counter and set that knob to C whick should be the CB frequency.
Feb 09, 2016 | Connex Radio Communications
General lee cb gets hot and stops transmitting and receiving.
Connex general lee - Mauldroppers CB Radio Forum
www.mauldroppers.com > Citizens Band Radio > Mobile DiscussionOct 23, 2012 - 13 posts - ‎7 authors Thread: Connex general lee ... amps and is getting cookin' hot when key'd for as little as 30 seconds, lol, truckstop hack job comes to mind lol.
Oct 02, 2015 | Radio Communications
Wanting info on my connex 4400 turbo how to peak and tune
unless you have the equipment to do this.. please take to a radio store. have them do it.. its free. or they shouldn't charge to do that service.. unless it needs a major factory alignment.
also they shouldn't take out or clip anything in the process if they do find you another place LOL..
Dec 24, 2012 | Connex 4400 320-Channels Base CB Radio
Can i get a connex turbo 4400 users manual
  • Yes you can. This is actually a service manual but it covers the basics found in the users manual in the first part of the first link. Also with a service manual you can dissect the radio to perform repairs.
  • Part 2 -
http://www.cbtricks.com/radios/connex/cx_4400_cx4400hp/graphics/connex_cx4400_cx4400hp_sm_pg16_pg33.pdf
Regards, Tony
Apr 30, 2011 | Connex 4400 320-Channels Base CB Radio
Radio receiving but not transmitting
There is a good chance you could have blown your final transistor. It could also be something is no malfunctioning in your mic. Is it on frequency? Hook it up to a frequency counter and make sure channel 19 reads 27.185. If it is your final transistor it blew for a reason. Most likely it got hot from a high SWR. 1-1:5 is the goal and no higher than 2. If it he SWR is higher then 2 the check your coax cables and adjust your antenna. Good luck.
Feb 08, 2011 | Connex 3300 240-Channels Base CB Radio
I need diagram connex cx 4400 power out put.
1-SHIELD
2-AUDIO
3-TX
4-RX
YELLOW-N/C
MAYBE THIS WILL HELP
Sep 26, 2009 | Connex 4400 320-Channels Base CB Radio
Rx/tx light flashes red and green at same time
sounds like a bad pll.that will have to go to a shop that knows what they're doing.good luck
Apr 01, 2009 | Connex 3300 240-Channels Base CB Radio
Correct wiring for a ASTATIC TEARDROP MIKE to a RANGER RCI 2950DX
here is the info you asked for the following is the correct wiring.
Mic Wiring Info
Stock Mic Wiring
1. Ground Shield
2. Audio Yellow
3. Transmit Red
4. Receive Black
5. CH. Up White
6. CH. Down Blue
Turner 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Black
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Turner 6-Wire MIC. Wiring
1. Ground Shield & Red
2. Audio White
3. Transmit Blue
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 4-Wire MIC. Wiring
1. Ground Shield
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Astatic 6-Wire MIC. Wiring
1. Ground Shield & Blue
2. Audio White
3. Transmit Red
4. Receive N/C
5. CH. UP N/C
6. CH. Down N/C
Mar 11, 2009 | Connex 3300 240-Channels Base CB Radio
Standard Microphone Wiring
Pin 1 is Shield(most mics this wire is bare copper) Pin 2 is Audio wire(most mics this wire is white) Pin 3 is Transmit(most mics this wire is red) Pin 4 is receive(most mics this wire is black)
May 30, 2007 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
108 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Mitch Davis
Mitch Davis
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
