Question about Food Mixers
How do I get the grinder repaired? - Food Mixers
    Top Expert:
  • 46,475 Answers
With no idea what make or model we have in question we can offer no suggestions
Posted on Apr 27, 2015
Where can I get repair parts & repair manual for my Frigidaire FD5125 All-in-One Mixer, Meat Grinder, Blender, 220 Volts?
go on line to the manufacturer customer or spare parts departments and make enquiries as to service centres near you
Apr 27, 2015 | Food Mixers
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
I have a kitchen aid 5 at. Mixer when I use my grinder attachment I notice oil/ grease on shaft what is that caused from
Sounds like a problem with the bushing around the accessory drive. If still under guarantee take it back and get it sorted. If out of guarantee take it to an authorised service centre.
Dec 15, 2014 | Food Mixers
The switch doesn't work on my grinder. got new one but terminals are different. is there a schematic for min0022 or 40744 grinder?
Best you contact the manufacturer so you do not burn out the motor by mistakenly attaching to the wrong posts.
Mar 14, 2014 | Vollrath 40744 22 Meat Grinder 1.5 HP 110V...
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
The attachment for grinding meat on the front wont work ? mixing arm in bowl works fine ! why wont it engage?
Firstly I would check it is fully engaged. If it is, remove the food grinder and look into the hole. You should be able to see a square hole inside. Turn on the mixer, the square hole should spin, if it does not, one of the gears inside the head has most likely broken. To repair this you will need to take the head apart.
The other possibility is that I misread your problem and that the grinder is turning, but the meat wont go through the plates at the end. This is a common issue which happens if the blade is not put in the end of the grinder. The blade is shaped like a cross and cuts the meat when it reaches the end of the screw.
Jan 25, 2010 | KitchenAid K45SS Classic Stand Mixer
My Super Grinder needs repairs
the blade of the jar got jamed, you have to remove the jar shaft and lubricat with any oil and refix it back
Feb 02, 2009 | Food Mixers
Put kitcheraid meat grinder back together
Proper assembly of the Food Grinder Attachment is covered in the attachment's Use and Care Guide.
Jan 11, 2009 | KitchenAid Food Mixers
MX-AC300 Mixer Grinder Got from India 2 months back Not working.Tried Reset Button too.
There is a great guy on Gerrard street in Toronto, who can fix mixer grinders and has parts also like breaker/reset switch etc.
The store is called Appliances 220, Ph # 416-778-9908.
Hope this helps.
Sep 24, 2008 | Food Mixers
Dry grinder
yes - dry well after wards
May 17, 2008 | Bamix De Luxe Hand Mixer
Food Mixers Logo
130 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
