Question about Worx Jaw Saw Wg307 - The Chainsaw Re-invented Jawsaw
The Jaw won't close... How do I fix? - Worx Jaw Saw Wg307 - The Chainsaw Re-invented Jawsaw
    Top Expert:
  • Worx Master
  • 51,187 Answers
Carefully remove all the screws you can find open the handle and look for a cam follower my neighbors daughter broke hers and had opened it lost cam follower . took me a couple days to find it she had not read the instructions and the chain had popped off inside . .
Posted on Apr 27, 2015
Tip
Flattering faces
When someone takes a close-up shot in the head, the jaw line can often find unflattering as Shadows Fall. For the jaw line more defined, ask the white paper in which to keep his chin
on Feb 21, 2011 | Cameras
What do i do if 2014 jeep grand cherokee tailgate will not close? it is beeping.
I am going to suggest check the grip jaw / that's what I call it it's the closure on door part that latches and grabs the latch bar or bracket on the other side the jaw maybe closed using a key in key hole turn key and screw driver sticking in between the jaw will open it if this is the issue
Jul 13, 2014 | 2011 Jeep Grand Cherokee
M1112 chuck .0045 off center
There are three possiblities: 1. dirt interfering with the jaw position or between the jaw and the workpiece - if you loosen, tap the jaw, retighten on your work and the result is repeatable, then this is not the problem. 2. the jaw itself needs to be cut, as you are doing - this will solve the problem and give you repeatably centering so long as 1 or 3 are not the problem. 3. The most insidious problem would be that the spiral groove on the back plate which is supposed to move the three jaws in harmony has a bad spot - this would give you inconsistent centering of the jaws at different diameters and could only be fixed by re-grinding that spiral groove (this would be VERY tricky to do yourself) or replacing the backplate.
good luck!
Jun 13, 2012 | Shop Fox M1112 Gunsmith Metal Lathe 2 Hp...
How to choose jaw crusher
it's necessary to make an investigation to choose credible jaw crusher manufacturer. as i know that Zhengzhou Hongxing Machinery, Shanghai Shibang Machinery are both good choices.
May 09, 2012 | Refrigerators
One jaw of the chuck will not retract
remove whatever bit you may have in the chuck, spin the chuck to its widest opening,, and give the one jaw that won't slide in a few small taps with a flush head hammer, once it goes back, lube with a spray lube Like WD-40 or better Tri lube,
May 16, 2011 | Drills
My trunk wont close the latch is hitting it just wont close what should I do!
on the sides of the trunk there are rubber stops they screw in and out. Try screwing them in and this should fix your problem
Aug 22, 2010 | 2003 Toyota Corolla
How do you use the crescent tool?
A crescent wrench is just an an adjustable wrench you turn the thumb wheel to either open or close the jaw to fit the nut or bolt you are working with. when using, the stationary jaw should always be up, or the adjustable jaw always down or the stationaryopposit the direction you want to turn. Real handy, but sometimes too bulky in tight places.
Oct 15, 2009 | Jack Lalanne Power Juicer 250 Watts
The ponies mouth
Hi, the pony's jaw is dislocated. There is a **** in the upper part of the mouth that you can look into to see where the jaw fits back in and can be popped back in place. There are also wire connections that may have come undone that can be reconnected easily.
Oct 15, 2008 | Hasbro Fur Real Friends Smores Pony
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Worx Jaw Saw Wg307 - The Chainsaw Re-invented Jawsaw Logo
167 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
