Question about Rug Doctor Mighty Pro X-3 Ready Pack Commercial Grade Deep Cleaner
Where do I purchase the vacuum assembly hoses inside the machine. mine are all split into
    Top Expert:
  • Rug Doctor Master
  • 51,596 Answers
Try the manufacturer
Posted on Apr 27, 2015
Vacuum is clogged
Without specifics of Model, I can't tell you how. There are no clog ports in Dirt Devil vacuums. Usually a hose has to be removed to unclog.
Apr 05, 2014 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Tip
How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
Here's the video showing how to replace the hose:
Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
Thanks so much,
Chris JonesGoVacuum
on Jul 26, 2011 | Bissell 12005 Spot Bot Handheld Vacuum
Repair wertheim 3180
The hose probably is old enough that it will split repeatedly until you give up and replace it.
Jan 10, 2018 | Vacuums
I can't get the hose portion apart to see why it is clogged?
There is a plastic retaining ring securing the hose to the rear of the machine. By removing the ring the hose can be removed and checked for blockage. If it is clear, you may have to remove the rear duct assembly and check inside. The large "J" shaped duct is held in place by eight # 20 torx screws. If this is clear, the valve assembly inside the rug nozzle may be broken and require professional repair.
Feb 28, 2011 | Hoover U6630-900 WindTunnel Bagless...
Hoover Floormate--Does not pick up water.
First make sure that you are getting suction from the bottom of he machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3000 floormate
H3000 Parts
Feb 07, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
My vacuum hose has split very close to the handle- how do I remove the handle, cut the hose at the split & reattach it to the handle unit - Centralux central vacuum system. Where can I find a diagram...
Do Not Cut the hose!
It has wiring inside to control the vac and power head. This is a swivel handled hose with both low and high voltage contacts in it. The same wiring which gives the hose its ribbing, is conducting current for two applications,
If your hose has a switched handle, a very experienced, trained AERUS Electrolux tech will a have a tough time doing this job and will likely refuse as it is not recommended per company policy.
You can purchase a shrink wrap tube which will prolong the life of the hose if it has not collapsed, however this is a short term fix.
I could walk you through this as I have done it before ...Unfortunately, even if you were able to dismantle the hose successfully you would not be able to purchase the wire terminals which you would cut off the end when shortening . Sorry its a proprietary part.
Sep 20, 2009 | Electrolux Centralux Vacuum
Hose to the machine split just above the connection
Not a fixable problem. You have to purchase a new hose assembly.
Sep 15, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
My steam vac deluxe does not have enough suction to pick up water
For the brushes:
The power wire may have slipped off. take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial.
for the suction, check the intake hose the comes out from behind the floor assembly. it tends to split over time
Aug 04, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate will not **** dirty water.
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Apr 20, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Water Uptake Hose Split
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=602269
Posted by jre8655 on May 16, 2008
How do you remove and replace the Water Uptake Hose Assembly?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Rug Doctor Mighty Pro X-3 Ready Pack Commercial Grade Deep Cleaner Logo
80 people viewed this question
Top Rug Doctor Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rug Doctor Vacuum Expert? Answer questions, earn points and help others
