Question about Jeep 2000 Cherokee Sport
How do you separate the check/fill transmission tube on 4.0L 4WDrive Auto Trans?
    New Friend:
  • 27 Answers
R Iooking to take the transmission tube out? If so u will ND to first chk where the tube & Trans meet if there is not a set screw or a small tactics weld you ND to move it back n forth it should come out good luck
Posted on Apr 27, 2015
Testimonial: "There was no set screw, so I moved it back and forth and it separated from the upper half of the tube just as Bigwhite Mullary said it would. Thanks!!"
How to check and fill the transmission fluid on a 1994 manual ford escort
check trans while running in park and warn, check trans dip stick under hood and if needed fill thought dip stick tube use a funnel for that do not over fill.
Sep 19, 2016 | 1994 Ford Escort
How to flush ford falcon 4,0L engine automatic 1996 model transmission
I'm not familiar with your vehicle, however the principle is the same for virtually all auto transmissions.
Get underneath your vehicle and look on the transmission fluid pan. Somewhere at the lowest point you will see a drain plug.
The plug may either be a nut or a recessed square, or even a hex recess.
Undo the drain plug and allow the transmission fluid to drain into a large plastic dish/container.
The link below shows you generic images of drain/filler plugs. It is not your vehicle:
auto transmission filler plug Google Search
When drained, replace the plug.
Then look for the filler plug. It will be higher up on the transmission case than the drain plug. Again, it may be a nut or a recessed square/hex.
You then have to use bottles of transmission fluid to refill the transmission. It can be messy ... The small bottles of transmission fluid - they have small tubes attached - can be very awkward to turn upside down when you're under the vehicle.
Alternatively, if you have a a long tube and a funnel you can use it to refill the transmission via the transmission dipstick tube. It can take a while to fill it as the fluid is slow to go down the tube.
Be prepared to get transmission fluid everywhere ...
Replace the same amount of fluid that came out. Start the car and move it through its range of gears. Check the fluid level.
It's not a difficult job. The link below is an easy guide:
How to Add Transmission Fluid
The job is worth doing. It will extend the life of your transmission. Most people never bother. Transmission fluid is supposed to be changed every 20,000 miles.
Mar 27, 2016 | Ford Cars & Trucks
Does a 2003 x type auto trans need to be flushed or is it a sealed trans
There are no sealed transmissions
All transmissions have a drain & fill
procedure
You can have it flushed,but I would never
allow anyone to disconnect any trans lines,
to do so, you chance dibris from flushing to cause
harm to transmission
If you have not changed trans & power steering fluids
on all your vehicles every 3 years, your almost sure to
have a failure at some point in time
There is lots on checking & filling- on the internet- if you
google the question & I expect You Tube Video will
show you how
Jan 25, 2013 | 2003 Jaguar X-Type
Where is the transmission fluid added to 93 nissan pickup auto trans
you fill it threw the dip stick tube where you check it from
Jul 07, 2012 | Cars & Trucks
Transmission oil fill tube nissan 93 pickup auto trans cant find it
should be on one side of the engine next to the firewall
Jul 07, 2012 | 1993 Nissan Pickup
Transmission oil capacity
For the auto trans, 2.5 litres. Differential, 1.6 litres separate fill. Type is Dexron III.
For the manual trans, 2.5 litres. Type is 75W-90 GL5 gear oil.
Mar 04, 2012 | 1991 Toyota Camry
WHILE DOING AN ENGINE OIL CHANGE I DRAINED THE AUTO TRANS FLUID BY MISTAKE. HOW DO I RE'FILL THE TRANS ?
Fluid Level Checking & Filling To Check:
  1. Connect a scan tool to the vehicle to read ATF temperature. ATF checking temperature should be 95° - 113°F (35° - 45°C).
  2. Start the engine.
  3. Raise and safely support the vehicle.
  4. Place a drain pan under the transmission.
  5. Allow the ATF temperature to reach 95° - 113°F (35° - 45°C). Automatic transmission fluid inspection plug vw-07-00-7273.gif
  6. Remove the inspection plug from the transmission housing. Fluid is pipe will run out. If fluid continues to drip out, no additional fluid is needed. If only the fluid in the overflow pipe runs out, additional fluid is needed.
To Fill:
  1. Pry the cap from the filler pipe. The cap locking device will be destroyed during removal.
  2. Pull the plug from the filler pipe.
  3. Add fluid slowly with VAG 1924 or equivalent until fluid runs out of the inspection hole. Install the inspection hole plug.
  4. Install the plug in the filler pipe and secure with a new cap.
Aug 17, 2010 | 2003 Volkswagen Jetta TDI
Where do I topup the auto transmission fluid
The dipstick for you car is the only thing I cannot remember.It will be to the back part of the motor and there is 2 in the engine bay.Its the one that is most probably towards the side.To check the trans oil level you warm the car up,park it and put the gears through all the gears and end up in nuetral.Now check the level.If it needs fluid,you fill it through the dipstick tube.SlowlyThe trans fluid bottles that you buy come with a tube to help fill the trans.Hope this helps
Dec 01, 2009 | 2000 Renault 181
2005 ford ranger 6 cyl auto trans - how to drain
I would pickup a plastic manual pump syphon hose, insert it in the transmission fill tube and pump out the appropriate amount. You should be able to buy on cheaply at most auto parts or home improvement stores.
Sep 19, 2009 | 2005 Ford Ranger
Dipstick
If it is an automatic, which I assume it is since you're looking for a dipstick, it needs a special fixture to add fluid(Dealer or foreign auto mechanic) or check level. If it's a manual trans, there is a check/fill plug on the end of the transmission behind the driver's side front tire, probably takes a 17mm internal hex head socket. Use 75W/90 gear oil, filling the trans until oil just starts to overflow through the hole.
Jan 05, 2009 | 1996 Volkswagen Cabrio
Jeep 2000 Cherokee Sport Logo
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
