Question about Amana Washing Machines
Went to change the wash temp on my Amana fold load washer and it locked up the only thing that is flashing is the Door Locked indicator light
    Genius:
  • Amana Master
  • 1,585 Answers
Door inter lock
Posted on Apr 27, 2015
Why does my amana front load washer hums and has a red blinking door locked light when I plug it in
The humming is coming from the motor. Sounds like the unit has overheated or sensed an electrical failure. The light indicates the same. It's either the door lock, iser interface or motor board. Call a qualified professional to fix this.
Nov 03, 2014 | Amana 3.5 cu. ft. Front Load Washer
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
Jun 24, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Indesit washer wont run
the door lock light flashing indicates that the door has not locked or not shut correctly,is the appliance is under 5 yrs old open the door and check the door catch,there are two gaps either side of the catch,if you look into the gaps you should see a metal pin,if the one at the bottom is not there then thats why the door wont catch,there are some screws around the door frame if you take them out and just pry apart the door frame by the catch you will see the pin at the top,push it down till you see it at the bottom gap,refit and test.
Jan 24, 2009 | Indesit W 123 Front Load Washer
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Door locked indicator light flashing
reposition the switch.. in the door
first try holding button at door with finger and press start..if same symptom appears...check tab that depresses that switch and if its good try to reposition or replace switch.
Feb 26, 2008 | Hotpoint WMA50 Front Load Washer
Open Questions:
Washing Machines Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
