Question about Garden
Trimmer/weedeater starts but when i apply the gas/accelerator it wants to die out on me, any solutions for this problem
    Top Expert:
  • 10,875 Answers
Buy a new carb from ebay for 12 bucks,it will cost more to clean the carb and rebuild it,use only non ethanol gas with small motors,ethanol kills carbs,should find that gas at any boat dealer
Posted on Apr 27, 2015
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Weedeater ght 180 wont start
You'll probably need to remove the carb and clean it out. Sounds like the fuel passages may be clogged.
Oct 05, 2012 | Weedeater Gas Powered Hedgetrimmer...
Poulan pro weedeater will not start without starting fluid and wont accelerate after starting Once started the first time it is easy to restart and idles fine, just cant accelerate the motor without it...
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
May 19, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Weedeater Hedge Trimmer
It's a 2-cyle engine. The oil is in the gas.
Jun 06, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I was using my weedeater yesterday when it killed on me, now i can't get it started. I have checked the spark plug and changed the gas ect. any suggestions on what is going on?
well, my 125l is the biggest peice of **** I ever owned... from the time I bought it, It has been nothing but a headache. By the time I get the damn thing started, I am not able to weedeat... I bought me a Stihl, Gosh, sems like I have died and went to Heaven.
Jul 18, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Jul 11, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater starsts and ildes won't run or accelerate
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
May 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Wont run when you pick it up or give it gas
Make sure your fuel line, with filter has slack to move around in fuel tank.
May 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
159 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
