Question about Electric Health & Beauty
Electric motor heats up and stops after using for about 15 to 20 minutes, when it cools it runs for a short time
  • Electric Master
  • 1,271 Answers
Hi, now there is a real possibility the brake is not releasing fully , stressing the motor out ,,, have you removed a brush to inspect inside ? what about smell, ? smell burning ?
, Carefully remove the brake and test but keep it connected ?
The windings here could be the issue if the brake is not causing the problem
Areas to look at are :
Brake
Brushes
Motor Commutator
Motor winding , have one of the magnets within the motor come loose... noise would be a issue here..
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jul 11, 2015
Ac works fine when fan is on low but fan cuts off after a couple of minutes on high
Bad fan motor. Multi-speed motors have a set of windings for each speed. Your high speed is bad so the only solution is to replace the complete motor. When motors are going bad they will over heat and kick out on the heat safety. As it cools back down it will start again for a short time again until it gets hot again.
Jul 12, 2015 | Coleman Dometic Duotherm Rv Air...
What causes my dryer to stop after 20 minutes?
Sounds like a possible motor over heating. The main motor has a heat safety built in that shuts it off if it gets too hot. It will restart once it cools off some. Over heating could be from excessive lint around the motor or even from a blocked vent pipe. All you can do is clean it well and check again. If it still shuts off the motor will need replaced.
Jun 03, 2015 | Dryers
If the motor is heating up more than usual, a couple of things
may be the source.
a) DC 24volt Motor itself has a shorted winding and using more current than normal. In that case the motor may need to be replaced. These DC motors have a commutated armature
that uses two carbon brushes. The carbon brushed do wear
down in time, so that could also be the source. The carbon
brushes are replaceable on pretty much all scooters and
can be obtained from MonsterScooter.
b) Controller issue where more current is being supplied to
the motor, but the motor itself determines how many amps
it draws from the batteries (ASSUMING FULL CHARGE HERE)
BASED ON THE BATTERY VOLTAGE, the lower the battery
voltage, the more current is required to move the transmission.
Apr 28, 2015 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Heat on at start, then will not come back on during cycle.
sounds like a bad thermistor? have it and the other thermostats checked with a multimeter. Lastly it may be bad windings on ur motor and the motor is going out, ( the sign for this issue is if it usually runs a short while then goes out, or stops heating, usually you will have to wait 30-to 60 minutes before it will run agin? meaning the motor needs to cool down and its going out?
Aug 15, 2014 | Kenmore Dryers
Kenmore series 90 washer runs for a short period and then stops
Sorry to be the bearer of bad news but what your describing is a classis sign of a bad motor. When the motor is bad it will run will its cool...when it heats up it shuts off and will restart for a short time when colled off till once again hot and shuts off again.
GENE
Oct 29, 2011 | Washing Machines
I have a kenmore series 80 electric dryer. It will will run for around a minute and then cut off. seems to be over heating. when I turn the heat setting down to the lowest setting it will run longer. If I...
that sounds like the dryer motor going bad,most of the time they run alittle then stop,or when you push the start button it just buzzes-mike
Mar 02, 2010 | Kenmore Dryers
When I start my dryer, I have heat at first, but it shuts off after a short time for the rest if the cycle.
It sounds like you have a gas dryer . The coils on the burner valve need to be replaced . They get hot from the electricity going thru them , and one opens (shorts ) until the dryer cools down . It should then heat again for a few minuted , then stop heating but still run . Your timer will not advance either , if set on auto , unless dryer heats . Without the model number , cannot give you the part number , so take it with you to get the part . It comes with both coils in a pkg .
Oct 11, 2009 | Whirlpool Dryers
Dryer runs for 15 minutes and stops
check the in-line limiters on the heating coil tube.
Jan 15, 2009 | Kenmore 62882 Electric Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
62802 stops running after a few minutes
It sounds as if you have a defective drive motor.  After the motor runs for a while and heats up, the internal thermal switch cuts it off before it gets too hot and becomes a hazard.  Once the motor cools down and the thermal switch makes up again, it will run and then repeat this process.
Oct 15, 2007 | Kenmore 62602 Electric Dryer
Health & Beauty Logo
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
