Question about Delta TS200LS Shopmaster 10 Inch Portable Bench Saw With Legs
How do I lock the blade tilting handle? - Delta TS200LS Shopmaster 10 Inch Portable Bench Saw With Legs
  • Delta Master
  • 1,874 Answers
How do i adjust the blade tilt
There should be 2 handles: height and tilt. Tilt is typically located perpendicular to the blade on the base of the saw.
Dec 28, 2014 | Jet Saws
Craftsman saw mod # 113-298051
The blade is able to be set to different angles by the handle under the front edge of the table. There is a lock handle to keep the angle set correctly. Loosen the lock handle, press a square (90 degree tool) against the flat of the blade - not the teeth - then lock the blade in place.
Craftsman 113 298051 Owner Manual rr
Jun 17, 2014 | Craftsman 10" Table Saw
How do I adjust the worm gear on my table saw?
I believe that that model of Powermatic has a lock for the blade angle that also extends and retracts the casters for moving the saw. You may have unlock or change the handle position to allow for blade angle adjustment. You can get a manual or information at the Powermatic website to show you how to change the settings on the saw. Hope that helps.
May 28, 2014 | Powermatic Saws
I'm missing a ''tilt'' set screw on my Craftsman 10 inch table saw
I couldn't find that model Sears saw to confirm, but if yours is like mine (113.298720), then the handle on the right causes the saw trunion to swivel left and right. And there is a locking hex-head bolt on the front of the saw up close to the underside of the table. This bolt locks the trunion in place keeping it from swivelling.
Take a look at the following diagram part 22 is the shaft that tilts the blade Part 30 is the bolt that locks it in place part 29 is the handle part 28 is the spring that holds the handle on the locking bolt
Mar 19, 2010 | Craftsman 10" Table Saw
My makita 2703 blade movement quirks
Here are two links for the parts manual and the owners manual. It is not uncommon for a tool to go slightly out of line with use due to vibration and and movement of the arbor. As for the tool not tilting, it just sounds like the worm screw and gear are off line. this is a pretty quick fix but it requires you to turn your saw upside down to access the set screws. I glanced at the diagram and it looks like the handle for the adjustment is held on by a set pin. you will also be able to access this from inside the cabinet.
Feb 24, 2010 | Makita 2703 10" Table Saw, Electric Brake
Craftsman model 708100 table saw tilt lock won't stay locked
Try removing the lock knob and putting a toothed lockwasher on the shaft. reinstall the knob.
Dec 11, 2009 | Craftsman 10" Table Saw
Bought model 3400 skil table saw. have no manual. can't find control for tilting blade. how do i tilt blade
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Feb 26, 2009 | Skil 10" Table Saw 3400
Can't rotate the blade carriage.
I guess that you are releasing the handle for the tilt? When released does it feel like it did? Does the carriage move any? What I would do is unplug the saw and put it on a workbench or floor and carefully tilt the saw on its back edge, holding the guard to keep if from falling quickly. Look under the saw for a bent rail and if not try to push the saw tilt by hand pushing on the bottom guard. You might have to lubricate the slide underneath or loosen up the locking mechanism. If you need a copy of the owners manual I would go to and typing in your model number to download it. I really don't think it is anything major. Let me know
Jan 15, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Delta TS200LS Shopmaster 10 Inch Portable Bench Saw With Legs Logo
188 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
