Question about Cell Phones
My phone is fine. However, when I plug my brand new set of ear buds into it, the sound goes in and out randomly. Why?
    Top Expert:
  • Cell Phones Master
  • 34,188 Answers
Those brand new ear buds may be defective.
Posted on Apr 27, 2015
sdowney83
  • 62 Answers
SOURCE: Can't always hear other person when using ear bud wint VX-8300
Make sure the ear bud isn't going bad, they are generally thin wired and poorly manufactured. Try a different set that is compatible.
If that doesn't fix it, take the battery out of the phone, get some rubbing alcohol and an old toothbrush and clean the headphone port.
And if that doesn't fix it, just get a bluetooth headset. Your pone is compatible and they can be found online for usually around $20. $40 for a descent set.
Hope this helps,
Simon.
Posted on Nov 19, 2008
  • 6 Answers
SOURCE: Sony Ericsson K300A cel phone headset connected, no sound
you have to put the headset profile on in your settings...
Posted on Feb 14, 2009
  • 30 Answers
SOURCE: i hav motorola s9 head
yaaaaaaaaa sure you can get it on amy communication shop just try n search for it
Posted on Aug 31, 2010
  • 7 Answers
SOURCE: I have model # MB702LL version 4.0(8A293) I have
Try the earbuds in another device and see if they work there, if they do work, try doing what's known as a hard reset (hold the sleep/wake and home buttons for about 10 seconds, until the phone turns off, and keep holding them until it turns back on, don't touch the screen at all during this process).
If that doesn't work, do a full restore of your phone in iTunes (after backing it up). If that doesn't work the problem is most likely hardware related, and there is little you can do besides take it back to the store.
Posted on Mar 28, 2011
SOURCE: Volume is non-existant on LG VX 4400
When you press vol up & down it will indicate "ringer ear jack." This means the phone is stuck in ear jack mode expecting a wired head phone accessory. Remove the battery then unscrew and pull out the antenna and the black plastic sleeve. Then remove the for small torx screws and carefully remove the back. Take a tooth pick to the back of the ear jack an bend the retainer pin back. Put everything back in reverse order and it should work fine.
Posted on Feb 20, 2012
Turn off the phone speaker when ear phones are connected?
that is a function of the ear phone jack some aftermarket buds do not plug far enough in to disconnect sound going to internal speaker tray another set
Jan 02, 2015 | Samsung Galaxy S 4G Cell Phone
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Jan 22, 2014 | JVC Gumy Ear Bud Headphone - Peppermint...
Why is there an audio playback glitch?
Old or worn Audio Tape Head needs replacing,
Head Cleaning tapes are not the best for these, they can only be used so many times and they do rub tape carbon into the tape head, best thing to do is get an ear bud cleaner -"Cotton Buds" - and dip it into metho and give the tape head a light rub with it and ear bud, should do it...if still has issue then the tape audio head is had it, but rarely do they breakdown.
Apr 25, 2017 | Canon ZR300 Mini DV Digital Camcorder
I purchased this mp3 on 11th devmber. the music is not getting through to the headphones - can you help? is it powered by a battery & is one included as standard?
Hi mharrington9,
You may want to post the make and model of your mp3 player. Someone may have solved the same problem with the same player, and would then be able to give you a more specific answer than this one;
I assume you have replaced or re-charged the battery first, and that full power to your player did not help. If so, it is likely to be a problem with the headphones, the headphone receptacle, or the amplifier inside the mp3 player;
1) Headphone problem?
Get a different set of ear-bud headphones, and try them out. If the alternative set works but your headphones do not work, it's the headphones.
1a) Large headphones, small player?
If your headphones are large, but the power of your MP3 player is small, the player may not have enough power to drive the headphone speakers. If you run your MP3 player through an additional amplifier, you may then have enough power to get sound out of your headphones.
1b) Broken wire in ear bud jack?
Most of my broken ear-bud sets have failed because one or more of the wires has broken, usually at the plug-end. There are 3 thin wires; If you break the left-channel or right-channel wire, only one earbud goes out. If you break the ground wire, both earbuds stop working, or you may hear a very faint sound at full volume. If you like to solder things, it is possible to get a new plug, cut off the old one, and solder in a new one. But it may be easier to get a new set of earbuds.
2) Broken Receptacle?
Plug your ear-buds into a different, working MP3 player. If the ear-buds work, then
Plug your MP3 into a computer through the data cable, and try to play something through the computer.
If the MP3 works through the data cable, something is wrong with the receptacle for your ear-bud plug.
You may be able to get your MP3 player replaced under warranty, since the purchase was recent. Or, if no warranty and you feel adventurous, take the back off and try to re-solder or replace the receptacle-- Though this usually ends in irreparable damage to the MP3 player :-\
3) Broken MP3 player?
If you can't get any music to play through the data cable or the computer, something is seriously wrong with the guts of the MP3 player. Try for a warranty replacement if you can.
Best of luck, mharrington9
Dec 12, 2010 | Audio Players & Recorders
The left ear bud wont work
This is usually caused by a short in the wire. The most cost-effective solution is to buy a new pair. "Shure" makes very nice ear bud headphones.
Sep 18, 2009 | Skull Candy Ink'd Stereo Ear Bud...
Losing sound in my Shure ear buds, they are one year old.
the wire breaks after a while in ear buds ,and head phones due to the constant flexing,and moving.they probably need to be remade.by cutting out the bad part of the wire(usually close to the fitting)You can usually wiggle the wire and find where the breaks are that way.it can be a real pain re soldering ear buds.also check the plug end by wiggling the wire there.
Mar 16, 2009 | Shure SCL3 Headphones
Feb 14, 2009 | Sony Ericsson W300 Cellular Phone
Two-Way Radio LI 5650 WXC -> ear bud doesn't work
Did you try plugging in the audio device before turning on the radio? If so, follow this by pressing the PTT on the radio once. It should clear the problem.
Dec 07, 2008 | Radio Communications
Lost ear phone rubber caps (phillips brand)
You can purchase new rubber caps for Philips earbuds on ebay from seller "auction2world". They are called replacement earbud cap. Unfortunately, you need to purchase the whole set of 3 different sizes.
May 17, 2008 | Lands Phones
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
