Question about HP 9200C Digital Sender
Yellow line showing on in scanned pages
I we use the feeder to scan multiple sheets of paper, a yellow line shows up in the middle of the scans.
If we just use the flat bed scanner, it doesn show up, cleaned all the rollers and the scanner glass, still has the problem.
Any ideas?
  • darlaB Dec 11, 2008
    My line is black going down the middle of the page. I cleand the glass and it still shows up.
  • HP Master
  • 2,022 Answers
If you can open the cover of the scanner just clean the glass and use any lubricant to apply on head rod to move smoother .
Posted on Nov 16, 2007
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
How i can scan multiple pages in one file ??
You need a document feeder. The printer has on or it doesn't. If it does you usually place the documents face up in the overhead feeder and the scan sensor in the printer will detect a load of paper in the feeder and choose to there instead of a single sheet under the glass.
Apr 17, 2016 | Artronix Technology Artec ViewStation AS6E...
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Unable to scan legal pages from feeder
Hi Nicole,
Improve the FixYa experience for everyone by voting.
There are two (2) things that I want you to try.
First, run the HP Scan Diagnostic Utility: CLICK HERE
Second, run the Microsoft diagnostic scanner. CLICK HERE
Hopefully, if you have a firmware or software problem, these two self-explanatory apps will solve your problem(s).
All the best,
May 08, 2012 | HP Officejet J4680 All-in-one Printer...
My scanner just started smearing the first page of a duplex to pdf but when I scan just front of document it doesn't smear it
Your question is not clear.
Sometimes using technical jargon makes it harder for people to understand each other (this applies to both askers and answerers).
I always advise askers to use normal language as much as possible and answerers to do the same and where jargon is unavoidable, to explain as they go along.
Please post again to clarify what you mean by "..a duplex to pdf..", in normal language not in technical jargon.
A PDF is not a real, physical document. It is a digital document on a computer or a webpage created in PDF format.
A Duplex document is a real document, printed on both sides of each sheet of paper.
If you are trying to scan a multiple page Duplex Document using the Sheet Feeder of your scanner, the ink on the reverse side may be getting caught up in, affecting and/or staining one of the rollers in the Sheet Feeder.
The bottom roller in most non-industrial Scanner Sheet Feeders expects to touch only the plain reverse side of a sheet of paper as it is passed through and turned over to rest on the Platten (scanning surface) of the scanner ready to be scanned.
Multifunction printers with built in scanners and sheet feeders and duplex printing capability are designed in a way that makes them more forgiving of dealing with duplex printed paper.
Duplex printing printed in a laser printer is less likely to cause a problem as long as it is allowed to dry thoroughly. Inkjet printing that is allowed to drry thoroughly should also be okay.
If the scanning is being attempted very soon after printing, then the wetness of the printing may be the problem.
Sheet Feeders that handle duplex printed sheets invariably become stained and need periodic cleaning.
If the document is not too long, you may have to scan it manually, page-by-page.
If the document exists as a PDF somewhere on your computer or on the internet, then it is unclear why you would need to scan it. This is why your question is puzzling.
Post a further comment, if this answer does not help you solve the problem.
I hope this helps.
Aug 25, 2011 | Fujitsu fi-5750C Flatbed Scanner
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Printer/Scanner Problems
Does the line show up on PRINTS FROM YOUR COMPUTER also, or only when SCANNING A DOCUMENT? If the line is only from scanned documents, the SCAN GLASS has something stuck on it. The SCAN GLASS is a GLASS **** located under the ORIGINAL FEEDER. It is NOT the plate of glass you place the original on . Look UNDER the original feeder for a scrap of paper stuck in the optical path of the GLASS ****, and remove the scrap, or CLEAN THE SCAN GLASS IF CORRECTION FLUID, INK, ETC ARE STUCK ON IT. If the line shows up on ALL prints, your CHARGE CLEANING SLIDER located in the IMAGING (DRUM) UNIT must be slid all the way to one end of the charger, OR IT WILL CAUSE A BLACK LINE ON ALL PRINTS. Otherwise, the IMAGING UNIT may need to be cleaned or replaced. Toner smudges on the drum would indicate need for cleaning or replacement.
Aug 12, 2008 | HP OfficeJet 9120 All-In-One InkJet...
Scanning multiple pages
Hi there
This could be one of many problems, i will tell you a few solutions that i know of, check the lid and see if there is a bulge in the middle of the lid (is the lid uneven in anyway?), if it is, i would suggest that you return your printer to the place where you bought it. This could also be a setting on your printer, the setting could be to scan a book or to scan two smaller pages.
If you would like a manual on how to sort this out (if the problem persists), please e-mail me at
Kind regards and good luck
Dustin Ellse
Jun 26, 2008 | Samsung SCX-4725FN All-In-One Laser...
Problem when scanning
If it is under warranty, contact HP.
Believe it or not, there probably is something in your scanner. Often times it is a very small piece of dust/fiber. If you are using the document feeder, the check the small piece of glass as the scanner bulb remains stationary and the paper is fed by. If you are laying the paper on the glass and scanning, then you will need to look at the scanner bulb itself. Run a scan with no paper and see if you see anything. If not, you can try to take it apart and clean the bulb (but do not touch the bulb with your bare fingers), with a light wipe of a tissue. If after cleaning, it either moves or goes away, then it is dust related. If it remains in the same position on the page, then there is a scanner bulb problem.
Nov 20, 2007 | HP LaserJet 2840 Printer
HP Officejet d135
take out the printer heads and clean.
Oct 24, 2007 | HP OfficeJet D135 All-In-One InkJet...
HP 9200C Digital Sender Logo
728 people viewed this question
Ben Johnson
