Question about Refrigerators
Where do I find the thermost at in a 12.4cuft we sting point fridge
    Top Expert:
  • Refrigerators Master
  • 44,428 Answers
Sorry check your make and model there is no( we sting point) made. in this world that I can find
Posted on Apr 27, 2015
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
Refrigerator side not cooling very well, freezer side working fine
on the fridge site check settings . if ok t could be fridge thermostate problem. this type of fridges have 2 thermostats one for freez and one for fridg
Mar 02, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Replacing thermostate in Westinhhouse WSE6100SA fridge freezer.
I would recommend an appliance service company for this type of work!
Feb 19, 2010 | Westinghouse Refrigerators
Freezer works fidge dont
Some fridges only cool the freezer, there is an evaporator fan motor that then blows are from the freezer into the fridge to cool it. You may need to replace the fan. ($30) It usually starts squealing before it goes. The fan is located in the freezer section probably at the top behind a vented cover. Check to make sure it spins very freely in not replace it. It could be your drain is plugged or frozen, pull out the fridge and look at the bottom to see where the hose enters the fridge, pour some hot water down from inside the fridge to see if it is clear if not, clear the hose.
Nov 01, 2009 | Dometic RM2852 Refrigerator
MY Bosch Refrigerator (KGU3420GB) does not seem to chill the top fridge compartment but the freezer seems ok(-18). Any suggestions as to what might be the problem. I suspect the thermostate control. I have...
you will find either 1) there might be a ice blockage on the evaporator. This in turn can stop the evap.fan motor which is supposed to circulate the frost .Defrost with a hairdrier once panel is off or switch orr for at least 2 days to defrost. (insulation is very good. retry.or 2) sometimes you have an auger at top of fridge compartment. If it sticks, reduces ability to cool.Also switch off. use hairdrier to remove ice build up at auger outlet. retry. .
Sep 20, 2009 | Refrigerators
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
Magic chef gas/electric rv fridge freezer gets cold but fridge dosn't
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Jul 15, 2008 | Magic Chef Refrigerators
Fridge freezing
Your fan in the fridge is proberally going bad,, check your fan
Jan 09, 2008 | Refrigerators
Thermostate problem
leave off for 24hrs to completly defrost, turn back on allshould work. Regards Advisor
Aug 18, 2007 | Maytag MFC2061HES Stainless Steel French...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
