Question about Grilling
85 22r webber misses3&4at idle - Grilling
    Top Expert:
  • Grilling Master
  • 51,191 Answers
What is this a new guessing game never had a grill that idles or misses .
Posted on Apr 27, 2015
Looking for a good 2nd hand 1600 crossfloww kent motor with 36 webber and 5 speed gearbox my motor is busted and i rather want to replace the motor
I built these engine on the assembly line ,couldnt you fit a OHC cortina engine as in the UK its not a issue with the paperwork and technical engineers like it is here in spain but finding a kent 1.6 GT lump with a webber carb nowdays ? ever heard of a brown stuff from a rocking horse?
Mar 08, 2014 | 1984 Nissan Pickup
We have a 3 week old Webber Q220 and the ignition does not work - plenty of gas but no spark
Sorry bout your luck. I have a webber. Cheaper modek, and it does the same thing. I.leave my lid closed ...turn it on wide open wait 30 seconds and start lighting.
Jan 01, 2014 | Weber Q Grill
I have a 1990 jeep wrangler yj . 4.2 with a used weber carb 36/32 . it stalls at a stop sign . the vacume lines seam to be hooked up ok the back port above the throttle is caped off the idle mixture s
The idle mixture screws do not control the idle. Is there no idle screw? If you have an anti-dieseling solenoid on the idle screw, make sure it is coming on with the ignition switch and use it to adjust the idle. Set the idle and then adjust the misture screws to maximize intake vacuum at idle. Readjust the idle after adjusting the idle mixture. The port at the back of the carb is not used in all systems. If you have a distributor with vacuum advance, make sure the correct carb post is connected to the distribtor. Adjust the choke and fast idle to engage when the engine is cold.
Jul 15, 2017 | Cars & Trucks
93 econovan new carb and head has air leak where else to look .new carb is webber so only runs advance hose and fuel inlet hose but if i cover the carb by hand idle,s properly
needs setting up right ,find a local mechanic whos a grandfather and he will do it with his eyes shut and one hand behind his back
Apr 28, 2012 | Ford Van Cars & Trucks
How to replace the carburetor with a high performance off road weber carburetor.
if you have a down draft carby, you can just buy an adaptor plate to suit a down draft webber if the webber doesn't just bolt on, or if you want to use side draft webbers, you'll need a new manifold too
Dec 24, 2009 | 1987 Nissan Sentra Wagon
Carb adjustments for a 1970's Ford Pinto 2.3 liter 2barrel engine
I have the Petronics electronic distributor kit for that motor ,jkjhenry@cox.net
Sep 15, 2009 | 1983 Ford Escort Gt
Poor idle
my truck was doing the same thing, i tried to adjust the idle screw and replace the ignition system but it didnt help. What i did was replace the carb with a webber and the problem was solved. I'm not saying to buy a webber but you might just need to rebuild your carb or something similar
Jan 13, 2009 | 1985 Nissan Pickup
87 mazda b2200
if it wont hold an idle then one or more of the cylinders are probably too low or high in compression and if it's backfireing then the ignition timming could be off. I would take a compressin test of all cylenders and if they are all in range I would hook up a timming light to se if the timming is out
Jul 02, 2008 | 1988 Mazda B2200
Grilling Logo
120 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
