Question about Janome DC2010 Computerized Sewing Machine
E1 showing in LED display. Why won't it sew?
I have done 3x everything the manual told me to.
    Top Expert:
  • Janome Master
  • 46,404 Answers
Contact Janome customer tech support personally do not like or use any HI TECH sewing machines for this reason . we can't fix them
Posted on Apr 27, 2015
My Janome Harmony 8048 continues to loose its memory which causes an E1 error. What can be done?
Internet research shows this may be a problem that needs to be addressed by a technician. Take it for service.
Questions Answers for janome e1 error
Jun 01, 2016 | Janome Sewing Machines
In the window then note comes up E1 ERROR . What is this. It does not sew.
Consult the owner's manual. There is usually a list of error codes in the Troubleshooting section that discusses error codes and how to resolve them.
Error Codes differ from brand to brand, so it is best to search for your machine's make, model plus "E1," ie:
Frequently Asked Questions
Why is my Kenmore sewing machine locked up with an E1 error code displayed...
Simple Fix for Janome E1 Error
Feb 14, 2016 | Sewing Machines
How do I fix the E1 error code?
Abnormal rotation in main motor Motor runs at more than maximum speed
Look HERE for Service Manual
May 22, 2012 | Brother CS6000i Computerized Sewing...
Elna 945 serger won't sew
you might consider having the machine serviced
May 14, 2012 | Elna Sewing Machines
My footup and footdown button is stuck and I keep getting an E1 error on the screen. Do I need to take it in for repair or is there something I can do to fix it? Machine will not sew because of the error...
Turn the machine off first and unplug.
If you've got a manual, look up the page for trouble shooting, this error message may be listed iwth a solution. I'd also suggest that you remove and clean out the bobbin holder. This is the little black piece you put the bobbin into. It has possibly dislodged if you've had a jam up. You will need to unscrew the two screws holding the needle plate down, take out the needle and pressure foot to give yourself some room too. Put the bobbin holder back into position lining up the red markings on the holder and the stopper, your manual should show images of this.
Once its all back together, turn on and hopefully it will reset to normal mode.
If you've done all this and the error message won't stop showing, then yes, you'll need to take it in for a service.
Jul 20, 2011 | Janome Memorycraft 6500P Computerized...
Display shows E1
I think I have the solution, it happened to me.
The instructions for bobbin winding tell you to click the start button for the bobbin to wind. When you do that you get that E1 with a beeping. What they don't explain is that in order to press that "UP" arrow button to get the bobbin to wind..........you need to UNPLUG the foot control. So, in other words it to be used for sewing w/o a foot pedal. Now instead of doing as per instructions, assuming you've plugged everything in (foot pedal), after winding is finished just press the foot pedal and your off and running or sewing as the case may be. BTW, look it up in the TROUBLESHOOTING SECTION OF YOUR MANUAL. Hope this helps.
Aug 14, 2008 | Brother CS6000i Computerized Sewing...
My Janome Harmony 8048 sewing machine came up with an E1 error. My manual says that this means that the machine is out of order. I've noticed that if the needle is lowered and then turned on, it will...
make sure the bobbin winder on the top of the machine is all the way to the left. otherwise the machine thinks you are trying to wind a bobbin and sew at the same time.
Jun 29, 2008 | Janome Harmony 2041
E1 error
The E1 error code indicates that a fuse is blown on the control board. The image below shows the fuse location. http://www.sewingmachineryrepair.com/forums/index.php3036358.gif
Jun 15, 2008 | Kenmore 19233 Computerized Sewing Machine
Janome 8000
I took my machine in with the same problem and they told me the display was bad. They told me that they did not make this part anymore. Try and find a parts machine.
Mar 16, 2008 | Janome 8080 Computerized Sewing Machine
E1 Error
If your sewing machine show's the E1 Error, then you have to open your sewing machine and replace the fuse.(you have to open the right Cover on Front where the Display is placed, because there is the circuit board placed!) There are 3 Fuses in the Sewing machine and they are placed at the printed circuit board. It should be the Fuse in the middle. (not those with the wire in it!) It's not easy at all to open the machine, the best thing you can do (if you have a Digicam) take some Pictures of the wiring so it will be much easier to put it back together. I'm NOT an Expert; but a passionate hobbyist. ;) If you are too; just save yourself further trouble with the helpdesk, and fix it yourself. I hope this post could help you!
Jun 16, 2006 | Kenmore 19233 Computerized Sewing Machine
Janome DC2010 Computerized Sewing Machine Logo
57 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
