Question about Dryers
How do you get to the the motor and blower in this dryer?
  • 932 Answers
Tara,
We need the make and model your dryer before we can be effective in helping you.
Posted on Apr 27, 2015
    Top Expert:
  • Dryers Master
  • 44,414 Answers
What is deyer
  • ray gallant Apr 27, 2015
    no make no model no help can we look for .
How do I get the old motor off to replace it if it is stuck
Remove the front blower cover assembly. Remove the round retaining clip on center of blower wheel. Pull blower wheel off motor shaft. Remove belt from motor pully. Pull out dryer drum. Remove clips holding motor to base frame. Remove motor assy. Easy peezy. Reassemble in the opposite manner.
Jun 21, 2014 | Whirlpool LEN2000PW Dryer
I can't get the motor shaft off the fan
From inside dryer hold blower wheel with wrench that fits the squre part of blower wheel turn motor shaft clockwise should loosen the blower wheel............
Jun 21, 2014 | Whirlpool LER5636P Electric Dryer
Blower motor not always coming on
the blower wheel is attached to the dryer motor if the motor is running the blower is moving unless the shaft end is worn out the blower threads onto the motor shaft
Nov 19, 2013 | GE Profile Harmony DPGT750EC Electric...
We have a air flow problem but exaust tube is not clogged no air coming out of bottom of dryer
On this weird dryer the blower is not mounted to the motor. Instead a fancy blower is mounted away from the dryer and requires a second smaller belt to drive it. What goes wrong? The drive pulley for the blower often falls off the motor. Locktite is recommended to keep the blower pulley secure to the motor shaft or this will be the result:
MAYTAG 2 BELT dryer innards
Aug 10, 2012 | Whirlpool Dryers
Does the GE harmony dryer have a blower motor that is driven by a belt?
No normally the blower is not driven by a belt, it is a motor with a blower wheel attached on the end of it...if the blower motor is not working then you will have to replace the blower motor
Oct 10, 2010 | GE Profile Harmony DPGT750EC Electric...
No heat blower motor no working
Okay, I think we need to back up a bit here. I need to know, first, if the dryer ignites. This is a GAS dryer, correct? I need to know if the igniter is glowing, and if you can hear the gas start flowing when you have ignition. If not, this could be a simple igniter or gas coil problem. If there is ignition and the drum is turning, do you have air flow coming out of the dryer vent exhaust? If there is air flow, you cannot possibly have a blower wheel problem. We need to rule out some possibilities before we start disassembling the dryer. I'm a bit miffed as to why someone would tell you that the motor was the problem. Since I was not there, I need to know as many symptoms that you can provide, so I can give you with a correct assessment.
Jun 15, 2008 | GE DPGT750GC Gas Dryer
GE Profile Electric Dryer, Blower nt getting up to speed
You need to replace the blower motor. It says you are having temp problems because the blower is quitting and the heater is overheating.
Jun 01, 2008 | GE Profile Harmony DPGT750EC Electric...
Blower Motor not working
This is not a board issue.It sounds like the blower is either broken or fell off the motor.Remember your dryer has 1 motor.On one side is where the belt is attached,and on the other side your blower is attached.
May 18, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryer not heating!! Harmony dpgt750ec
If you have tried all the normal fixes for the harmony dryer you might be having a problem with your blower motor. To check, remove your dryer vent and start the dryer. If you have no air moving then your blower motor has stopped. When the blower motor is not running then your dryer will not heat. This is one of a few models that have a seperate motor for the blower so most techs will miss this. Good luck to you, mca0824@aol.com
Apr 26, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
55 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
