Question about Magic Chef Refrigerators
Magic Chef mini fridge HMBR445WE, turns on gets to temp but that's it,compressor does not turn on unless I turn the temp control off and on again. it does not get the signal to turn on by itself.
  • Magic Chef Master
  • 5,323 Answers
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts.
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Posted on Apr 27, 2015
SOURCE: magic chef gas/electric rv fridge
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Posted on Jan 09, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
Posted on Apr 27, 2009
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Posted on Aug 04, 2009
Sea Breeze
  • 4655 Answers
SOURCE: my mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
Posted on Aug 27, 2009
hiltonjug
  • 612 Answers
SOURCE: Magic Chef mini fridge stopped working. I hear a
You have either a bad capacitor or a bad compressor. If I were there I would put a part on called a 3 in 1. It's made by Supco. It replaces your relay Overload and start capacitor. If the compressor is good, it will fix your problem. Click on this site and you will see the part I'm talking about. It's very simple to put on. http://www.appliancepartsonline.net/index.php?target=categories&category_id=50 The part number is RCO410
Please rate this solution and good luck!
Posted on Sep 05, 2009
Testimonial: "Very helpful. I'll try it."
My magic chef 4.3 refridgerator is not cooling properly. I have a lot of food in it and frequently (every few hours) I check it and I have to turn the temperature control off then on for the ccolness and...
When the compressor is working it will be cooling the refrigerator to the desired set temperature,when the desired temperature is reached the compressor will stop, that is quite normal....it will come back on again when the set temperature drops......the more that you open the fridge, the more the compressor has to work as everytime the door is opened the temperature inside the fridge will go up.
Dec 04, 2013 | Magic Chef Refrigerators
Stops periodically
possible compressor or fan overheating and shutting off
Dec 08, 2017 | Magic Chef MCBR445S1 Stainless Steel...
My Magic Chef Mini Fridge just stopped but the compressor is hot.
ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Aug 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Fridge won't start, tries to but clicks off after a few seconds
compressor is broken if you are under warranty you can get it replaced. if not you should buy another one cause compressors are expensive to replace. costs about the price of a new refrigerator. you can try getting a used one from classifieds or craigslist.com
Aug 26, 2009 | Magic Chef MCBR440 Compact Refrigerator
My mini fridge will not work. compressor is hot.
Aug 23, 2009 | Magic Chef MCBR440 Compact Refrigerator
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic chef fridge not working
Could also be beginning of defros problem.
Jun 04, 2009 | Magic Chef CTB1821AR Top Freezer...
Apr 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic chef fridge RB193A
Which fan is working or are all fans working, condenser clean, hear compressor running ? Let me know.
Apr 22, 2009 | Magic Chef Refrigerators
Refrigerators Logo
103 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
