Question about Vizio Televison & Video
When I plug in my Vizio E601i-a3e it displays "no signal", then flashes. What's wrong?
I replaced the main board but still flashes.
  • 494 Answers
Check to see if the HDMI cable is plugged in properly. Also may be a bad connection with your coaxial cable, redo the fitting or a new cable. Also check your source of signal as the input is selectable.
Posted on Jun 30, 2015
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
  • 362 Answers
SOURCE: My Vizio 55XVT1A power on, has sound, but no picture. I changed new power board, main board, T-cond board, but it still same problem. What's wrong with it? Is it anything with inverter board? Than
If this is an LCD tv the backlight inverter is bad, a good way to check it is to shine a flashlight close to the screen and see if you can see a faint picture.
Let me know what you find
Posted on Feb 19, 2012
SD Tech
  • 14553 Answers
SOURCE: AKAI LCT37Z6TA TV Issues
Sounds like the main board as it has all control and signal processing on it.
Posted on May 17, 2012
  • 5 Answers
SOURCE: vizio e320vl stays onm for 2 seconds and shuts off i have replaced main board and power supply what can i do next?
did you use the same RAM-memory on the second main-board ?try different ram memory, it might solfe your problem.
If it does, your first main-board whill be okay to.
please keep me informed.
Bart
Posted on Jul 22, 2012
SOURCE: Vizio GV42L shuts down after startup
I had this exact same problem, (while TV is off) pressing and holding the input button worked perfectly for me. Thanks jdberk
Posted on Sep 16, 2013
I have a Vizio E601i-A3. The "Vizio" emblem does not light up and the screen does not light up. Is it most likely power board that needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 26, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
My tv is Vizio E601I-A3E. thereis no display ...how can i fix it
Yes but only if you have skills in electronic parts testing procedures and a DVOM meter and the repair manual for the set.
Sep 12, 2016 | Vizio Televison & Video
Vizio E601i-A3E (no power). I have replaced main power board and entire power cord assembly. Anything else i should be looking at?
The main board sends the on/ off signal to the power supply board. If a new power supply doesn't fix it, then the main board is faulty.
Aug 30, 2016 | Vizio Televison & Video
Hey Guys, My tv won't power on. No light indicating it is plugged in. Tried to reboot. Confirmed outlet works. tech support suggested a new Main Board. Vizio TV: E601i-A3E Serial: LFTRNWCP4704603
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 11, 2016 | Televison & Video
Two vizio TV's with issues
Take them to a TV repair centre as they are complex to repair. You may find that your homeowner insurance will pay for the repairs if you can demonstrate that it was a power surge that damage them.
Feb 29, 2016 | Vizio SV421XVT 42 in. LCD TV
I have a Vizio E601i-A3 model # LFTRNWAN4909536. The screen comes up and reads "no signal" none of the controls on the side of the tv function and the remote control isn't working either
http://electro-medical.blogspot.com/
Jan 25, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
My vizio e601i-a3e doesnt come on, no led , checked power and the wall and it is good
Go to you tube type in your question and you should get the video you need to sort out your problem .
Dec 21, 2015 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I have a Vizio 60 inch LED TV E601i-A3E We changed the main board & power supply Still makes a clicking noise when you turn it off. Volume will not turn up and down. We have also done factory resets.
Have you checked there is any short circuit to its T'Con board. Sounds so. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 20, 2015 | Vizio Televison & Video
Televison & Video Logo
62 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
