Question about Samsung 24 " White Dishwasher With Stainless Steel Tub - DW80F600UTW/AA
How is a temperature sensor replaced on a Samsung dishwasher?
I'm getting an error code indicating a temperature sensor error. I can buy an OEM replacement part, but where can I find installation instructions?
    Top Expert:
  • Samsung Master
  • 36,385 Answers
Go to www.repairclinic.com and enter the model of your dishwasher. You will be presented with an illustrated list of common replacement parts and may also be able to view a video showing the replacement process.
Posted on Apr 27, 2015
2 Suggested Answers
mhrasna
  • 99 Answers
SOURCE: I have a 3 year old Samsung DMT800RFS dishwasher. It had a 9E error, so we changed the part on the side and replaced the interior gasket. Now we get a oE error and I can not enter Service Mode to re
I don't know if this is the same. However, on my washing machine I had to clear out the water trap at the bottom of the machine. I know I have to clean it out every 6 months to be on the safe side. This also helps the machine to not smell like old stagnate water and helps your clothing smell fresher with not having that water build up and sit. I found all strange things in all kinds of water overflow tubs.
Posted on Dec 20, 2014
MAYTAG OVEN ERROR CODE F3
Hi Janine.
F3 means "Shorted oven temperature sensor" and it is returned when the oven electronic control detects a wrong impedance value from the oven temperature sensor circuit.
The oven temperature sensor is a probe located inside the oven cavity. The sensor can be removed from the oven and tested using a multimeter set on impedance. The impedance reading across the two sensor's contacts at room temperature must be about 1100 Ohms. Impedance increment rate is 100 Ohms more for every 50 degrees temperature increase. If the reading is sensibly different from this value the sensor must be replaced.
Here the replacement part:
Long Oven Sensor Kit
The sensor is indicated as part number 11 in the exploded view available here.
The sensor is held by two screws. In order to replace the sensor disconnect power, disconnect the connector attached to the sensor, undo the two screws and remove the sensor. Perform operations in reverse order to install the new sensor.
Regards.
Ginko
Jan 15, 2012 | Maytag Ovens
General Electric Radiant Slide-in Range JSP39: The oven does´nt work, in the screen appear F-3 very often, and inmediatly it gets off, sometimes appear F-2 and then gets off
These codes indicate an over temperature condition. The F2 & F3 error codes both mention the temp sensor. The temp sensor is mounted inside the oven cavity & regulates the oven set temperature. If the temp sensor fails the oven could overheat. This is what generates the error codes. I recommend having the temp sensor checked with an ohm meter, at room temperature the sensor should ohm out at approx 1100 ohms. If the sensor checks ok, then the control will need to be replaced.
Jan 20, 2011 | GE Profile 30" Self-Cleaning Slide-In...
What is code 23 for pontiac grand am is it vacume leak
Wow these are hard to find!!
Diagnostic codes for 1987 Pontiac
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Vacuum Control
33 Mass Air Flow Sensor (MAF) (GM/SEC High)
34 Mass Air Flow Sensor (MAF) (GM/SEC Low)
41 Cam Sensor Circuit
42 C3-I EST or Bypass Circuit Failure
43 Electronic Spark Control (ESC) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 PROM Error
52 CALPAK Error
55 ECM Error
If you have your owners manual they should be in there. I couldn't find one online but did find this.
Future reference
http://autorepair.about.com/library/ts/obd-i/bl-dtcs-28.htm?once=true&
I hope these helped you
Nov 26, 2010 | 1987 Pontiac Grand Am
Gives codes F-2 &F3 what is the problem jachin2145@comcast.net
Hi, Error Code F2
An F2 error code indicates a failed connection with the keypad. Ensure that the connection between the keypad and control board is tight, and press the "Cancel" key. Wait one minute to see if the error code returns. If it does, the keypad is defective and needs replacing.
Error Code F3
F3 error codes are triggered by problems with the oven temperature sensor. You cannot tell whether the sensor has shorted out or has simply failed to generate a reading if your Whirlpool range only displays two-digit codes. On a Whirlpool range with four-digit error codes, the F3-E0 code represents a failed temperature sensor and F3-E1 represents a short in the sensor. Regardless of which code is displayed, replacing the temperature sensor is the only way to correct the problem.
Hope that helps.
Thanks for using fixya...
Oct 27, 2010 | KitchenAid KESC300 Electric Kitchen Range
Hello - I have a Compool 3600 system and recently I started getting an ERR 1 message on my control center. After doing some research, I ordered a replacement temperature sensor (TS5L with red and green...
With the information that you gave above I come up with this.
1. You got an error 1 message which indicates a bad WATER TEMPERATURE sensor.
2. You installed the sensor and you got the same message
3. To test it you removed the sensor and got an error 3 instead.
This is what identifies the problem.
The sensor that you swapped must have been the FREEZE TEMPERATURE sensor and not the WATER TEMPERATURE sensor.
The error 3 code only comes on when the FREEZE sensor is diabled or disconnected.
Solution: Trace the TEMPERATURE sensor and replace this sensor. The original freeze sensor is probably still good if you still have it.
Check out this manual and refer to page 38 "problem solving"
http://www.pentairpool.com/pdfs/cp3600OM.pdf
Refer to page 18 for the low voltage wiring diagram to find and trace the water sensor
Sep 22, 2010 | Pentair Pool & Spa
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
Kenmore Gas Range model # 362.75491990 F3 error Oven will not hold temp - error message displays and beeps I Replaced the oven temp sensor same issue Is the control panel bad?
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect.
these are some other code error that will help you in case of next time.
  1. Step 1 Press "Off/Cancel" (or "Cancel/Off" depending on your model) to clear the error code. Note the code if it reappears.
  2. Step 2 Replace the touchpad if the code displayed is "F0," "F7" or "F10." A function key is stuck or shorted.
  3. Step 3 Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
  4. Step 4 Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
  5. Step 5 Replace the ERC if "F5," F6" or "F8" is displayed. The ERC is the main control unit. "F5," F6" and "F8 are codes that indicate problems in the ERC functions.
  6. Step 6 Inspect the door-lock assembly and circuit if "F9" is displayed. The door must lock when the oven is in use. If the lock mechanism is not functioning or if the detection circuit is malfunctioning, the stove will display "F9."
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
"F3" codes mean your oven temperature sensor has failed or shorted out. The only thing you can do is to replace the sensor.
Take care.
May 11, 2010 | Microwave Ovens
BMW 325ci - Car cuts off on very hot days - Error code P00128
Check the following :
BMW Code PO128
This means that the engine's PCM detected that the engine has not reached the required temperature level within a specified amount of time after starting the engine. The intent of the P0128 code is to indicate a faulty thermostat. Similar codes: P0125
In determining the engine did not reach a "normal" temperature, it takes into account the length of time the vehicle has been running, the intake air temperature (IAT) sensor reading, the engine coolant
temperature (ECT) sensor reading, and the speed of the vehicle.
You will likely not notice any drivability problems other than the MIL illumination.
A code P0128 may mean that one or more of the following has happened:
  • Low engine coolant level
  • Leaking or stuck open thermostat
  • Faulty cooling fan (running too much)
  • Faulty coolant temperature (ECT) sensor
  • Faulty intake air temperature (IAT) sensor
solutions
Past experience indicates that the most likely solution is to replace the thermostat. Verify coolant strength & level
  • Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
  • Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
  • Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
  • If the above items check out good, replace the thermostat
Aug 18, 2009 | BMW 5 Series Cars & Trucks
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
Whirlpool RF196LX Smooth Top Range
4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Oct 21, 2007 | Kitchen Ranges
Samsung 24 " White Dishwasher With Stainless Steel Tub - DW80F600UTW/AA Logo
147 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Di Nagy
Di Nagy
Level 1 Expert
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
