Question about Electrolux Microwave Ovens
What causes error code F1 in my Electrolux convection microwave EI303BM60MS?
  • Official Brand Answer
  • 4,342 Answers
Thank you for your inquiry, Leanne!
From the information you have provided your Electrolux microwave is displaying an error code of "F1". I am showing that an "F1" error code is not valid. I would recommend resetting your microwave and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue and you continue to experience an "F1" code please reconnect. -Matt
Posted on Apr 29, 2015
Emc38905x Does not start. Select microwave, then power then time press start & nothing happens. Need to toggle the power to reset & ok for afew days then fails again
I have an ELECTROLUX MICROWAVE (Model : EK23CBS4) purchased in January-12 from Pune. During usage glass plate got automatically cracked. when i called up service centre they said glass plate is not covered under warranty. When I verified the warranty book there is no as such things are mentioned. Most of the customer having the same problem glass plate getting cracked automatically. So I will suggest do not purchase any of the product Microwave Oven of ELECTROLUX. This is our responsibility avoid any product to purchase of ELECTROLUX.
Thanks, Mritunjay Kumar Cell# - 9922385632
Nov 06, 2011 | Electrolux E30MO65GSS Convection Microwave...
I WOULD LIKE TO DOWNLOAD MANUAL FOR ELECTROLUX MICROWAVE/CONVECTION/GRILL OVEN MODEL EM20EC80SL PLEASE
I found it! There isn't a direct link from the Electrolux home page (shame on their webmaster!), but I got it with a search engine.
The first 12 pages are important generic information about microwave cooking; after that it gets into details on your model.
Mar 08, 2011 | Electrolux E30MO65GSS Convection Microwave...
I am getting an F1 error code for my frigidaire and my oven will no lnoger work......any suggestions?
Hello there:
This is a oven sensor problem in the microwave
I would contact your nearest appliance dealer for parts support and replacement advise
F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Nov 02, 2010 | Microwave Ovens
Kenmore Elite micro/convect model 64289. Convect not heating...F1 error
F 11 code. it is a touch pad error.
if you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 18, 2010 | Kenmore 63672 Convection/Microwave Oven
Error Code F1
If you just cleaned the control panel it may have water in the panel causing a key to stick.
May 04, 2009 | GE JE1390 Microwave Oven
Sca2000fww 02 trouble code F1
F1 This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced.
Good Luck
Please rate FixYa!
Dec 18, 2008 | GE Advantium 120 Convection/Microwave Oven
ELECTROLUX EMS2487X 900 WATTS CONVECTION
these are the numbers for Electrolux, 877-435-3287
706-228-6615
You might also want to try registering your oven online at the electrolux website and they might be able the e-mail you information as well...hope this helps
http://www.electroluxappliances.com/node69.aspx
Nov 08, 2008 | Electrolux EMS2487X Convection Microwave...
After preheating, the convection oven displayed F1 and did not heat further
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
^&^%tg
Jan 29, 2008 | Kenmore 64282 Convection/Microwave Oven
Microwave Ovens Logo
234 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
