Question about Retail Supplies
How do I clean out programs and reprogram? - Retail Supplies
  • Retail Supplies Master
  • 1,749 Answers
Cleaning out programs is a bad idea as you will make a LOT more work for yourself. Editing existing ones to suit your business is more effective. Run through your programming manuals and change the things you need to
Posted on May 02, 2015
Kenwood 272g won't receive on fire dispatch channel. To hear what they say I have to hit the transmit button. It then blinks orange and green. I got it with the channel working but when it was reprogrammed...
Check the battery and antenna. Clean the antenna contacts. If it was reprogrammed, then have the programmer look at the programming. Something was done wrong. Unfortunately, it is easy to make a mistake even with professional software. Nothing is user adjustable or changeable.
Mar 03, 2015 | Kenwood Radio Communications
91 olds toronado won't start battery has full charge.key may need programmed?
Only reprogram if you know it needs programming otherwise you are wasting your money. Take the key to a main dealer and ask them if the programming is still working as you are having trouble starting your car.
They should be able to tell you if it needs programming or not.
Apr 12, 2014 | 1991 Oldsmobile Toronado
Reprograming replaced ECU
Do they need reprograming, dont they come ready to install. I have never pre programed one. Only programed after installed in vehicle to change power curve or fuel settings not really sure what you mean
Mar 30, 2014 | 2011 Nissan Rogue
Can the brain box be reprogramed and if so how
Some cpu units can be reprogrammed using a laptop with the programming sequence in it . On the later vehicles the dealers can alter the cpu program to give different engine performance. Talk with a shop that specialises in vehicle performance to see if yours can be reset
Feb 21, 2013 | 2003 Saturn VUE
How program the key remot
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.If the remote s faulty then keyfob will not get programmed.Insert the key in ignition.Turn the key to on position,and cycle the key three times off-on-off-on-off-on.Then with the keyfob remote select your remote and then try to operate the vehicle with remote.These is just the basic procedure,but sometimes it will not help.
On that case dealer is the only option.
---------There are few very relted troubleshooting links mentioned below for remote key fob reprogramming.I suggest you to go through the list and click the link below to go through its details and procedure:-------
2009 Toyota Highlander: Smart Key Not getting Detected? http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
----------2007 Toyota Prius: Reprogram Remote Keyfob? http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
----------- Pin that holds the flick key part to the key fob? http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key? http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
----------Where is Key chip memory located on 2004 ford Freestar? http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
----------Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
----------After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure? http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
-----------Audi A8 Key Fob Programming?
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
Oldsmobile Aurora Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
Buick Lesabre Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
Keyfob remote not working on 2003 Ford E350 Econoline?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start on BMW?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Mitsubishi Car Key Not getting detected after replacing ECM http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
----------- Key Fob will not lock and unlock doors?
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
2000 Jeep Cherokee Limited: KeyFob Remote Not Working? http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
----------- Chevrolet Malibu: Key Stuck in ON position? http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
----------- Theft indicator not letting car to start?
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
2012 Dodge Ram: Ignition Key will not release? http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.Thanks.
Nov 23, 2012 | 2006 Toyota Tacoma
1998 CADILLAC SEVILLE STS I GOT A REBUILT ECM COMPUTER WAS CLEAN AND PROGRAME TO THE VIN , DOES IT NEEDS MORE PROGRAMING OR JUST INSTALE?
if it was done at a GM dealer (reprogramed) it should be ready to install. if not it may not operate.
Jul 15, 2011 | 1998 Cadillac Seville
How to reprogram two way radio, its a motorola gp 339 and its set to 5 channels from when i brought it, can i reset it or reprogram it to normal uhf channels?
In order to reprogram this Motorola GP339 you need to have a programming software, radio interface box and programming cable for this radio then you can read and change frequency in it. To reprogram to UHF channels this radio must be in UHF band. Good luck!
radcom907
May 14, 2010 | Motorola GP300 Compatible 2 Way Radio...
My Viper 791XV will not remote start my 2005 F150 anymore. It will attempt short cranks, but will not start the vehicle.
I have the same problem with my, the keydrop program is not there anymore. it has to be reprogrammed. I have a Ford Expedition and was told that fords drop the programs sometimes.
Jan 05, 2010 | Viper Security and Remote Start System...
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Reformat sony ericsson k608i
how to reprogram sonny ericcson k608i when its not switching on?
Mar 27, 2008 | Sony Ericsson K608i Cellular Phone
Retail Supplies Logo
76 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
