Question about Cub Cadet Garden
My cub cadet model E18J just shut off and made a large pop sound and now it will not turn back on what can it be?
    Top Expert:
  • Cub Cadet Master
  • 10,875 Answers
Check if it turns over by hand,check fuses
Posted on Apr 27, 2015
Testimonial: "Did that also still not starting"
  •  johnny rebel
    johnny rebel Apr 27, 2015
    battery or solenoid,check for voltage at all items,pull the ground wire off of coil and try too
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
How do I find year model on Cub Cadet rzt 50
The Manufacturers Serial and model numbers should be on a plate under the seat. Go to the Cub Cadet Website navigate to Manuals, enter the Serial/Model numbers and the year of manufacture should pop up.
Sep 21, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Manuals for cub cadet lawn tractors
Try running a google search for the model # you're inquiring about. Something should pop up giving you multiple choices on where to buy a manual.
Jun 21, 2014 | Cub Cadet Garden
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet LT-1042 blades spin when motor is turned on, pto lever does not turn on or off blades
sound like you have some wires shorted out follow the wires from the clutch back to the switch
Apr 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet e18j will not start
Apr 01, 2012 | Garden
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Won't start. Runs well when it does start.
the solinoid for the starter motor needs replacing
Jul 07, 2009 | Garden
Garden Logo
74 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
