Question about Sewing Machines
How do I fix my sewing machine from selling reverse
I changed some of the settings on the stitches but I don't believe the back button is stuck
    Scholar:
  • 104 Answers
A machine reverses by reversing the rotation of the feed dogs. Make sure there are no bits of material or thread in the lower rotating mechanism of the feed dogs that are preventing it from moving back to its normal position. You probably have to remove the thread plate, bobbin, and bobbin holder to access this area. Use the hand wheel to manually operate the mechanism to see if you can locate the problem.
Posted on Jun 03, 2015
RickE1
  • 202 Answers
SOURCE: Viking Husqvarna model 6440 gets stuck in reverse
There are numerous things that can cause this, some very simple, some less so.
1. Fortunatly, the most common one is also the simplest to cure. When you turn the selector (upper left) knob between stitches, one of the things that is happening when you feel the resistance is that it is lifting the followers off the camstack so that it can move to another stitch. When the camstack is normally doing its job, lifting the feed cam follower is what puts the mechanism in reverse. So, while the selector is between stitches, the machine is temporarily in reverse. Also, the dots where the dial is to be placed to change the camstacks is between stitches, so if the dial is on these dots or anywhere else except snapped into a stitch, you will get nothing but reverse.
2. The buttonhole mechanism is stuck in the reverse portion of the buttonhole. Usually if this is the case, the needle position will also be stuck on the left side, and the width control /buttonhole control will not function correctly. Usually you can correct this yourself and I'll explain how in a bit. It is usually caused by lack of use of the buttonhole mechanism.
3. Either the arm that connects the camstack to the stitch length block or the block itself is stuck. Both these parts are spring loadedto bring them in the forward position, so long periods of rest are a contributing factor.
All of these causes except for the first one are because of the mechanism not being exercised frequently enough. These older Vikings do not like to sit still very longYou should fully exercise all the knobs at every sitting.
Ok, try this fix. And this is to free up the mechanisms that are probaby stuck from non use and old oil and grime buildup. Take your seamformer (cam) out of the back. Find a hairdryer and blow some heat in there for awhile. This will soften up any hard oil or grease that may be causing the mechanisms to stick. Then if you can it would be best to have what is called TRI-FLOW oil (the BEST) and spray or drop quite a bit into there covering the mechanisms and let it soak in. You might try a good sewing machine oil soaking or WD-40 in small amounts. Little by little test your knobs, slowly working whatever is stuck lose. Never force the issue. Small amounts of movement little by little will eventually free it up.
Good luck. Hope this helps. If this does not help you may have to take it to a technician and hopefully you won't find out that your take up slide isn't broken which is a major job.
Posted on Nov 25, 2007
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
  • 323 Answers
SOURCE: reverse sewing button stuck HELP!!
MOdel 6430 has the stitch length and buttonhole selector on the same knob. It is the one on the bottom right side of the machine. I believe you may have selected the buttonhole by pulling out on the large round knob. You need to turn the knob back to 0 zero and push in. This should return the machine to normal mode.Adjust your stitch length to 3 and try it. The reverse knob in the center should also stick out so that it becomes operational again.
sewman7
Posted on Jun 05, 2008
bilabon
  • 46 Answers
SOURCE: Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Posted on Jul 29, 2008
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
The reverse stitch button is stuck in (or broken) and machine only sews in reverse. Can this be repaired?
Have you followed your user guide instructions re making needed setting adjustments back to a sewing mode? Have you checked the guide for instructions on 'resetting to factory default' so that you can reprogramme?
If the above doesn't help, have you tried a 'shock reboot'? Start by turning on machine on and let it sit for a few minutes then without turning it off, pull the power plug from the electrical outlet. Wait five minutes then reconnect and turn on your machine - it should have defaulted back to factory settings. You'll lose your saved stitches but your machine should function properly again.
If that doesn't get your machine sewing forward, something the wee man did snapped something inside the machine (usually a gear and the things are easier to 'snap' than people realise) and it's time for a trip to the repair tech...,,THIS IS ALL I COULD FIND ON THE INTERNET..plus this manual...
http://janome.com/siteassets/support/manuals/retired/computer/inst-book-mc4000.pdf
Dec 06, 2016 | Sewing Machines
What is my Janome 415 feeding the fabric backwards? How do I fix it?
You have the reverser in the back stitch setting. When you do an over lock stitch you change the feed direction. It should be a lever. Some have a screw lock to keep it in place.
Aug 19, 2014 | Sewing Machines
Why is my Janome Mystyle 20 stuck on reverse?
It may be in the buttonhole mode, change the stitch selector to straight stitch.
Jul 16, 2014 | Janome Sewing Machines
Kenmore 352.15202/15208
There is a button that activates reverse, when released it will sew forward again....
Jan 22, 2014 | Sewing Machines
Husqvarna prisma 980
since the sewing machine was given to you, it might be a good idea to have the sewing machine serviced to see if there is a problem with the reverse and stitch setting.
Aug 14, 2013 | Sewing Machines
My brother ce8080prw machine will not stitch in reverse and is stuck in abasting stitch. how do I reset?
My machine was also not sewing in reverse and stuck in a basting stitch. It was a simple fix. Unscrew the plate and remove any pins stuck in there. All fixed
Nov 04, 2012 | Brother SE-270D Computerized Sewing...
Singer 4423 stuck on backstitch!
Is sewing machine set for buttonhole making? Sounds like it got "confused" in the process of a buttonhole revolution making a reverse stitch, and so you need to change adjustment settings top left, bottom right, remove extension table and turn feed dogs switch back left of machine to UP position.
Did this help?
Jimmy
Dec 13, 2011 | Singer 4423 Sewing Machine
Reverse stitching on a singer 514, HELP!
In the center of the stitch length knob (at the right side of the machine) is a button. You would push that button in to get the machine to reverse.
May 08, 2009 | Singer 7442 Mechanical Sewing Machine
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Reverse sewing button stuck HELP!!
sewman7
Jun 03, 2008 | Husqvarna Viking 1
Sewing Machines Logo
67 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
