Question about Dishwashers
The pots and pans and the 2 delay keeps blinking. Dishwasher won't work. What do I do
  • 53 Answers
Turn thepower to the unit off at the breaker panel for 30 seconds or more to see if it will reset the unit. hope it does and good luck
Posted on Apr 27, 2015
    Top Expert:
  • 10,875 Answers
Wash them by hand
Pots and pans light keeps blinking and not working on Whirlpool Gold Dishwasher - what do I do?
Pots and pans requires HOT water. If your heater is not working it will not run the cycle. Possibly the heating element is bad or has become disconnected. Only has two wires coming in from the bottom of the dishwasher (underneath behind the kick panel). Do not touch them unless you know power to the DW is off. Heating element is nothing but a high resistance wire in a tube so you can check it with an ohm meter. Continuity means it is good. AS LONG AS that continuity is not with the outside tube.
Not hard to replace it but up to you to decide if it is more trouble than you want to do.
Sep 15, 2012 | Whirlpool Dishwashers
How do you get the Codes? for GU1500XTL Dishwasher. Only buttons that work are: Anti Baterial, Pots n Pans, Delay Start, Air Dry, and Cancel. We normally use NORMAL. Need Codes and Wiring Diag. Thanks Walt
I am having the same issue. Did you find a solutions? Looks like websites I've searched talk about resetting the controls by hitting either high temp wash -> airdry -> high temp wash -> air dry OR saniwash -> air dry -> saniwash -> air dry. I'll have to try that tonight.
Oct 20, 2011 | Whirlpool 24 in. GU1500XTLS Stainless...
Unit will not run. cannot enter diagnostic mode.
i would say that you have a bad touch panel..99 percent positive
May 10, 2010 | Dishwashers
Pots and pans and normal lights blinking
That reset sequence code didn't work for me. We tried everything on a ton of forums.
What I did to fix our Whirlpool dishwasher was to disconnect the drainage tube from the garbage disposal. I noticed it smelled really bad so I figured it was clogged. I used a bucket to catch the water left in the tube. I took the sprayer from the sink and flushed out the tube. 4 pumpkin seeds and a couple of beans landed in my bucket. I flushed it a couple times. I hooked the tube back up to the disposal and sure enough all the lights returned to normal. I pressed start and it came on.
Feb 22, 2010 | Whirlpool GU2200XTSB GU2200XTSQ 24 in...
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Aug 09, 2009 | Kenmore 13743 Staimless Steel Built-in...
Quick Rinsw button blinking
I may have fixed my similar problem- I opened up the machine to get access to the control panel as tech17 advised- then in addition to disconnecting the mylar ribbon, I disconnected all the connections to the control panel.... keep in mind to ensure not to confuse any of the connectors you disconnect. Running a cycle at this time... seems as if working.. can't tell if water is running or just the motor- -- HA! -- i confirmed no water being pumped in.... We then found a float switch (Item 30 on schematic) that got loose from its casing on the front interior right lower side... we put that switch into its proper place and now ALL IS WELL!!!! Yippee!!!
Feb 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Lights on pots and pans blink constantly
try disconnecting power for a bit. try the cord under the sink. if its hard wired (no cord) you can try the breaker.
may reset itself.
otherwise, you have a logic board issue.
consult the manual first for explanation of blinking lights etc.
then call the mfg for further info and if needed, schedule an approved repair person.
good luck
mark
Dec 21, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
85 people viewed this question
Top Dishwashers Experts
Owen Barnes
