WHEN RUNNING WATER OR AFTER SHUT OF A PULSATING HUMMING NOISE OCCURS
  • 53 Answers
Thats probably the pump making sure all the water is out,mine does that too then shuts down
Posted on Apr 27, 2015
Refrigerator has developed a low buzz or hum. Do I need to be concerned?
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator, LFHT1817LW1, is buzzing or humming. With modern, high efficiency compressors you may hear a high pitched humming or pulsating sound. Additionally, if you have an icemaker equipped inside of your refrigerator the water valve may produce a buzzing noise as the valve opens to fill the icemaker with water. I hope this has been helpful. -Matt
Oct 15, 2014 | Frigidaire Refrigerators
N-069m pulsating when hot water is turned off.
Do you have a well our on city water? Check in coming water pressure make sure it is not over 60psi
Sep 14, 2014 | Noritz 6.9 Gallon Residential Tankless...
Frigidare microwave has humming noise when not in use
You have a shorted cook relay.
Apr 26, 2013 | Microwave Ovens
Pulsating humming from rear even when in Park
It is always helpful to know the make, model, and year of the vehicle. I assume that the engine is running when you hear this noise? Just from what you describe, i would suspect that what you're hearing is the electric fuel pump in the gas tank. If you turn off the engine does the noise stop? (i hope so!) It is not uncommon to hear a noise like this coming from the electric fuel pump. When cars accumulate a lot of years on them, the pumps tend to become more noisy over time. If the vehicle has 100,000 mi or more on it, it could be a sigh that the fuel pump is wearing out. Have you had any problems lately with it, like stalling, etc.? If it is running ok, i wouldn't worry about it unless you're having operational issues. you could be hearing it now because original insulation or rubber stand-offs on the metal lines have deteriorated or worn down and are conducting the noise. If it were me and i was really concerned, i would start the car, set the emergency brake and chock the wheels and get underneath it to see exactly where the noise is coming from. It could be something as simple as something just vibrating while the car is running. hope this helps a little
Apr 10, 2013 | Honda Civic Cars & Trucks
High pitch/humming noise from Frigidaire Refrig.
You have to isolate this problem. It could be one of three things. The compressor, the condenser fan motor or the water valve that feeds the ice maker and wtaer dispenser. Also if the high pitch sound is compared to that of a bird then it is definitely the condenser motor. To isolate the problem take the back cover off. LISTEN FOR THE HIGH PITCHED/HUMMING NOISE! Use a flash light and see if you can tell where it is coming from while it is doing the noise. Dont try this unless you know what your doing. Stop the condenser fan blade with the end of a hard object, but stop it gradually. Dont try this cause you might brake/bend the blade. But if you did and the noise stop then you figured out your problem. If not ythen disconnect the water valve. It has to doulble harness wires attached to it. if problem still exisit then it has to come from the compressor. Unless you have a warranty then theres nothing no one can do except change it. $300-400 job easily.
Mar 27, 2010 | Frigidaire FRS26RLECS Side by Side...
Noise coming from the rear end of my 2004 honda pilot it really only occurs during cold weather and after it warms up you hear it slightly
When does the noise occur, while driving only, or driving and idle, in gear, or in neutral and park? If it occurs all the time (while driving and at a stand still in cold weather) it could be the fuel pump. If it occurs only while driving, it may be a wheel bearing. Describe the noise (humming, grinding, whirring, etc), and what is the mileage on the Pilot? Answer my questions so I can fine tune my answer. Thanks!
Mar 18, 2010 | 2008 Honda Pilot
No water , when running, loud pulsating noise
Usally when there is no water comming in it is the water inlet valve. First turn selector swith to see if it is only hot or cold water that is the problem. Take the hoses off the back of the washer and make sure that when you turn the water on that there is lots of water pressure comming out of the hoses. If ok. its probably the water inlet valve. There are two screws holding the valve from the back. Access the valve. Remove the fill hose from the valve. Remove the four wires off the valve and put on the new valve. Reinstall fill hose and install valve with two self taping screws you took out. Put your hoses back on and your ready to go.
Dec 22, 2009 | Kenmore Washing Machines
Help
First you should have checked the voltage and amperage on your friends charger. Sounds as if it was not correct for you computer. Pulsating sound often occurs when too much amperage is applied. Sometimes you can get lucky and just mess up the battery. Try removing battery and pluging in your power cable to see if you can atleast get your system running again. If not the result will not be one that you will like very much unless you were about to be replacing your laptop. Always make sure you read the labels on any replacement power cords.
Jan 21, 2009 | Toshiba A205-S4577 Notebook
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
