Question about FIC AM 37 Motherboard
Motherboard Installation I installed a new motherboard and nothing happens when I turn the computer on. Is there a way I can test to see if the mobo is working properly?
  • 31 Answers
There are a number of issues that may be causing your problem.
1. Be certain that the power connection is properly installed; there are usually two connections not one that go from the power supply to the motherboard.
2. Be certain that there is no metal on metal contact between the motherboard and the case. Most modern cases include nylon snap-fit spacers that hold the motherboard to the case but also use brass spacers with screws. There should be red paper gaskets included in the parts bag - place these between the motherboard and the screw and be certain that the base ring (a silver metal ring that is not connected to circuits on the underside of the board) is cleanly centered.
3. Finally there are often switch settings and/or tab jumpers that must be set to declare the CPU type, voltage and speed. Be certain that these are set correctly or the board will not power up.
It is difficult to provide any further tips due to the limited information provided and more information may help.
Posted on Nov 14, 2007
I built a computer for my aunt using an Intel motherboard, Intel processor, 2 x 500MByte DDR3 RAM in a Blue Ninja case purchased from Tiger Direct. The computer worked well for more than two years then...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 16, 2011 | RaidMax Ninja Case (RDMXNJACAS)
Foxconn mobo
try to look on the jumper settings on the motherboard before you upgrade your proccessor maybe they need to be adjusted.tryb to put back the one wich was there and see what many beeps does your computer makes when you switch in on?if it makes more than one then your proccessor is not compatible with the board.a computer should beep once whenevever its switched on
Sep 06, 2008 | Foxconn 945GZ7MC-RS2H Motherboard
Motherboard not powering up
check the smps its purely smps problem
Jul 21, 2008 | Intel D915GAG Motherboard
Hi rex, you can download all the drivers you need for the 7VM400M-RZ motherboard directly from Gigabyte here.
These drivers are free.
Once downloaded & uncompressed you can burn the to a CD.
Jul 13, 2008 | Intel Motherboard
RAM Installation.
your new ram fsb speed not support your mobo
845glly mobo support 266 fsb 133 mhz sdram
Feb 29, 2008 | Intel D845GLLY Motherboard
Not booting up.
can you get into the bios?
Nov 01, 2007 | Gigabyte GA-K8NF-9 (890552602964)...
P4i65G - brand new want start.
Try getting a slower cpu, I have a 3.0Ghz P4 with 512mb of ram and it works great, I emailed them about upgrading ram and they said: "Upgrading the memory would not affect the Video card, unless the memory is not compatible with the motherboard, then the computer might not turn on at all."
Oct 24, 2007 | Asrock P4i65GV Motherboard
Motherboard Installation Problem - Intel DP35DP
Have you tried clearing the CMOS, and rebooting with a standard keybord and mouse. ? (non usb)
Oct 12, 2007 | Intel Motherboard
Problems with Mobo? Or CPU?
Hi, have you checked your RAM chips? Could be they have worked loose while traveling, make sure they are firmly seated, otherwise you may have to take it to a technician. Goodluck mistyman
Sep 04, 2007 | Gigabyte GA-M55SLI-S4 Motherboard
No beeping, no video displayed.
hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Jun 30, 2007 | Abit LG-95Z Motherboard
FIC AM 37 Motherboard Logo
154 people viewed this question
Top FIC Computers & Internet Experts
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
