Question about HP Office Equipment & Supplies
Trying to print from my zte world to train HP 4501 printer and I can't seem to find the print button
    Top Expert:
  • HP Master
  • 10,875 Answers
Do you have the print app??
Posted on Apr 27, 2015
Error code c-4501
replace the print head which houses the LASERS. located under the drums as one large assy.
Mar 16, 2014 | Konica Minolta Bizhub C550
My hp 2550L keeps printing faint blue lines down one side of the page. Does this mean that my blue cartridge is bad and needs to be replaced or do I need to do more to fix it?
I'd try giving the cartridge you have a good shake first.
If the line is still there, then I would give HP a call to troubleshoot it because those cartridges are expensive, and if they determine that the cartridge is at fault, then they will replace it free.
1-800-HP-INVENT
Even if the printer is out of warranty, they should troubleshoot a print quality issue free because chances are that the toner is still IN warranty.
Drums and toners and cartridges have an out-of-the-box warranty meaning that if you purchased your toner 8 years ago and took it out of the box last week, it's still under warranty !
Don't let them tell you otherwise - if you get a poorly trained phone center agent, they may not be aware of this policy. The Canadian phone agents usually are the ones that seem to be well trained enough to be aware of this long standing HP policy with respect to Laser consumables.
If you get someone in the Philippines, it's usually best to just hang up and try again!
8:00 AM-6:00PM EST seems to be best when trying to get the Canucks.
Jul 25, 2011 | HP LaserJet 2550L Printer
I need to print off the configuration page nicludng the DHCP given IP address
When the printer is in the ready state, press the go and cancel buttons at the same time and a config page will print.
Dec 23, 2009 | HP Color LaserJet 2550n printer + HP Color...
Did a black print cartridge refill at Costco. It
You used one of the worst refill services available. There's a reason they have a flat rate for refills, they use non cartridge specific inks, don't clean out the cartridge, and have a machine not a person do the thinking and the work for them. You will have similar failure on cartridges refilled by Walgreens, Office Max, and cheap online refills. I suggest Cartridge World first then Office Depot for refills. They have high quality standards and recycle your cartridges by refilling them.
Dec 18, 2009 | HP Photosmart 2610 All-In-One InkJet...
I had my cartriges refilled and now its not printing correctly. actually printing in all yellow. I've tried cleaning the heads and turning off printer to rest. I've tried to align and clean printer heads....
Unfortunately in my opinion your cartridge has been compromised. Hopefully you did not pay for this service. You should replace that cartridge immediately. When it comes to cartridge "refilling" if you are not going to "do it yourself" don't even let someone else do the deed even for "FREE"
Nov 05, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Shows catridge empty
If you want to use this non-
HP print cartridge, press
(Cancel Job) to continue printing.
Dec 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
HP Color LaserJet 2550n printer - Paper feeding fine. No print!
Have you checked that you are sending the print job using the correct paper tray on the printer? Check the properties of the printer to ensure you are. Check also that the printer is OK by running a test print from the printer and not through the PC. If I remember it's hold the green button for around 7-10 seconds, whilst powering on.
Dec 29, 2006 | HP Color LaserJet 2550n printer + HP Color...
Seeker5211
Seeker5211
