My unit isn't reading CD disc, It's reading DVD disc fine, just not reading CD blanks. Is it format or disc type?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
Some players can read every format of writable CD. Check at the manufactures website to see if it is compatible or not.
Posted on Apr 27, 2015
Can i use any type of blank cd format i.e. MAXELL,TDK,SONY cd/cdr/cdrw. On a TASCAM CD-RW5000 or Do it just take the DIGITAL AUDIO/COMSUMER TYPE ?
What does the instruction manual say about what to use?
Personally I buy Taiyo Yuden and have never had a problem. In Radio we used a lot of CDRW900 units and they used them many times a day using standard data discs. Name brand discs like Maxell and the rest are there for profit- they don't make discs so they do not regulate the quality. Go to supemediastore.com and read up on media quality and you will end up with what I use.
Aug 13, 2012 | Audio Players & Recorders
Disc rejection
Try using a DVD / CD cleaner disc in the unit - this might fix the problem - I had the same format error on a Toshiba unit using Sony and VBerbatim discs - once cleaned the unit worked fine
Mar 25, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Display Reads - No Read or UNSUPPORTED when using DVD
If you cant play a real dvd in it, the laser is prob out of allignment or broken, if its just dvd that you burned, try changing disc type, there is +R and -R , also if that does not work try a different program to burn discs ? good program is convert X to dvd, not free, unless your good at torrents :)
Jul 11, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Cdr is not reading blank disc shows disc error
A few small things to try. Turn off unit, unplug for 5 minutes, plug back in, turn unit on.
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Sometimes spindle dvd blanks have a few bad ones.
Check manual, might describe exactly what types of dvd blanks are best to use with the unit.
Just some suggestions, hope this helps.
Apr 27, 2010 | Denon CDR-W1500 2-Disc CD Recorder
NEC DVD +RW - 6650A will not read a blank DVD
i ran into this problem a while ago. I had to test different dvd's. I then looked on the manufacturer's website. there they stated which dvd-r, dvd-rw would work. once i tried that brand It worked fine.
Sep 10, 2009 | NEC ND-6650A DVD RW Dual Layer Burner
I am trying to record to a blank dvd-r. I load a
If exact model is Samsung DVD-VR357, than it doesn't even has to recognise blank disc as your unit is DVD PLAYER with Video Casette Recorder.
See Specs. for your unit below:
Function Combination VCR Y Compatibility Playback Media DVD-R,DVD-RW,DVD+R,DVD+RW,CD-R/RW,CD,VHS, DVD-RAM Playback Formats MP3, WMA, JPEG, MPEG-4, DivX A/V Quality Progressive Scan Y HD Upconversion 720p/1080i Digital-to-Analog Converter 10-Bit/54MHz DTS Output Y Dolby Digital Surround Sound Y Connectivity HDMI CEC Y Convenience Child Protection Parental Control Physical Features Connectivity HDMI Output Y Component Video Output 1(Rear) S-Video Output 1(Rear) Composite Video Output 1(Rear) Coaxial Digital Audio Outputs 1(Rear) Optical Audio Output 1(Rear) Product Weight & Dimensions Dimension 16.9" x 3.1" x 11" Weight 8.8Lbs. Shipment Weight & Dimensions Dimension 20.2" x 7.1" x 15.1" Weight 12.1Lbs.
Closest model match for DVD recording unit would be DVD-VR375
Unfortunately you have player only and you won't be able to recor DVDs with it whatsoever.
Good luck
Jun 24, 2009 | Samsung DVD-VR357
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
My Philips DVD8421 burner will not recognize a blank DRD-R disc.
Ok, the reason is quite simple. The Philips DVD8421 does not recognise the DVD-R format.Not all DVD/CD burners read all discs. It does recognise DVD+R though. So all you need to do is use these discs instead. This should solve your problem.
Hope that helps.
Dec 05, 2008 | Philips (JR24CDRW99) CD-RW/DVD-ROM (Combo)...
Lite-on Combo SOHC-5236v
You may be using the wrong type of DVD format. Some DVD-ROMs and players will only read certain discs. i.e. DVD+R, DVD-R, DVD-RAM. If you are trying to read a DVD-R disc that was bought blank, and then had things burned to it, it may be that the disc wasn't finalised after burning. You could always try updating the Firmware version by downloading it from the website.
Nov 08, 2008 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
