Question about Jobar Extra Wide Talking Scale
Looking for set up instructions for Jobar international ji-20636
I can't figure out how to set it up.
My mother gave this scale to me without set up directions. Can you help me set it up?
I believe JI-20636 is not a model denomination. Couldn't find any reference to it. What is the make of your scale?
Apr 26, 2015 | Health & Beauty
Instructions for jobar scale jb5824
The jb5824 Jobar scale was working perfectly until it seemed to need a battery change. Dimming, not coming on all the time... We changed the 9v and not it just displays 0.0. We cannot get on it it does nothing. Can someone help me find a manual or some troubleshooting ideas? It seems to want to work. Thanks!
Jan 14, 2013 | Jobar Extra Wide Talking Scale
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
I just received product JB5413. Batteries were just purchased today. The remote is working fine, but it will not weigh. The instruction manual is minimal. I need help getting this to work.
If it's any consolation my Jobar/Ideaworks JB5413 scale has the a similar problem: will not weigh, yet the remote control functions okay. About one attempt out of ten will cause a weight display, though. Can't figure out why scale works occasionally, vs. never works. Batteries are new, and the battery compartments are free of corrosion.
Jan 15, 2011 | Jobar International Ideaworks Remote Read...
Jobar international JB5413 large cap. scale It shows in kg i want to change it to pounds.
press WT then press SET for 3 secs
then use up/down arrows to change between kg lb and st
when selected press SET again
Dec 07, 2010 | Jobar International Idea Works Wireless...
Just purchased the Ideaworks Large Capacity Bath Scale with infrared receiver and I can't get it to display the weight. The receiver seems to be working (can set clock, lbs, etc. . . ) but nothing happens...
If it's any consolation, my Jobar/Ideaworks JB5413 has developed the identical symptoms, although occasionally it will start working briefly. Batteries are new, and no corrosion in the battery compartments. I am thinking about just junking this nicely styled scale; what a shame.
Apr 22, 2010 | Jobar International Ideaworks Remote Read...
New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Jan 16, 2010 | Jobar International Idea Works Wireless...
Jobar Extra Wide Talking Scale Logo
124 people viewed this question
Top Jobar Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Jobar Health and Beauty Expert? Answer questions, earn points and help others
