Question about Samsung Televison & Video
I have a Samsung LNT4053HX/XAA given t me from a hotel. When I power the television on it is on ch. 62 and "snow". It appears the television has no OS since I am unable to change channels/volumes
    Top Expert:
  • Samsung Master
  • 51,521 Answers
Sad to say but you were given their junk .
Posted on Apr 29, 2015
Model LNT4061FX/XAA Intermittent snow then picture. Is there a cure?
Intermitant snow means your tv is not getting signal continuously. Please check the input signal connection and source to your tv.
Dec 26, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
CODE FOR UNLOCKING V-CHIP
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
Jul 15, 2012 | Televison & Video
How to off samsung cs21-m16mj crt tv hotel mode
when the hotel mode is on you will always get the display. see the on screen display is comming. if it does not appear it means there is a fault in the tv. if appears you can go to menu & find "hotel Mode" in picture submenu & put it off.
Sep 26, 2011 | Televison & Video
Video is snow. no images just lines and snow. the only menu that appears on the screen is the net command set up menu. after a couple of minutes the TV powers OFF no matter what i try. i tried pushing the...
A suggestion: try with the original Mitsubishi remote to do the soft restore: Menu, 1,2,3, enter.
BEFORE YOU RATE THIS SOLUTION LET ME KNOW WHAT YOU FIND.
SD TECH
Jul 05, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I need the code that will tske my samsung 40" out off hotel mode
hello,
To switch off hotel ode on samsung, enter:
1. On standby press info-menu-mute-power or,
2. press mute-1-8-2
After service mode appear, Choose option block,
Fine Hotel mode, change to off.
If in option block you can't fine it, try open other block.
Good luck.
Apr 16, 2011 | Televison & Video
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung 42'' model no.ln-t4053h 8 mod code#lnt4053hx/xaa
The panel costs over $800 to replace. The broken/cracked panel cannot be fixed as the glass inside is cracked. It is not worth repairing. However, I would be interested in it for the parts. If you still have it, would you be open to selling it to me at a reasonable price? Please call me at 310-770-1444. Thank You, Jeff
May 18, 2009 | Samsung Televison & Video
Televison & Video Logo
67 people viewed this question
Jerry Greenberg
Jerry Greenberg
