Question about Microsoft Zune JS8-00001 Digital Media Player
Anti theft reset - Microsoft Zune JS8-00001 Digital Media Player
Keyfob battery dead, theft mode on. 2008 Cadillac CTS
Tip & How-To about Cars & Trucks
Resetting a Vehicle Anti-Theft System This is how you reset an anti theft system if you have the anti-theft light on, or your car is cranking, but you have no spark.
Doing a full reset of the anti-theft system.
Disconnect both battery leads for at least two hours.
Hold the negative and positive leads together for 5 minutes to fully discharge any power.
Put the key in the ignition, but not turned on. VERY IMPORTANT!
Connect the positive lead.
Connect the negative lead in one swift movement.
Wait 15 minutes for the system to fully reset.
Posted by Andrew... on Jan 14, 2018
Resetting Vehicle Anti Theft System
Aug 17, 2018 | Cars & Trucks
Where is the fuse for 2001 nissan x trail anti theft
There isn't one. It is controlled by the engine control unit, the ECM, the cars computer. There is no way to bypass it, you have to fix the problem. I have never heard of a vehicle with a 'code', only for radio?
Want to bypass your vehicle security system
Have you tried to reset it?
Jul 29, 2018 | Nissan Cars & Trucks
How do i reset anti thief system for my 05 Dodge neon? May u please help me i cant seen to figure it out.... Thanks
Jun 16, 2018 | Dodge Cars & Trucks
2002 jeep grand cherokee laredo anti theft wiring diagram
This is because you key chip and ignition chip are not known to your new ECM!
May 26, 2018 | Jeep Cars & Trucks
How do I reset the anti theft on the car?
Apr 15, 2018 | Cars & Trucks
I have A 2006 chevey HHR and I need to reset my new fob?
Mar 10, 2018 | Cars & Trucks
How reset computer 2007 lincoln towncar
It is the same as this
Jan 20, 2018 | Lincoln Cars & Trucks
2006 Ford Explorer sport trac anti theft kill switch
2006 Ford Explorer sport trac anti theft kill switch ???? There is no reset button for the anti- theft . Dealer !
Aug 24, 2017 | Ford Cars & Trucks
07 ford focus anti theft light flashes all the time
If the security or anti-theft light is flashing when you attempt to start your car, and the engine does not crank or does not start, you have an anti-theft problem. The system may not be recognizing your key's key-less entry signal, or there may be a fault in the anti-theft module or wiring.
There is a reset procedure to stop this anti-theft light flashing.many a times this helps The reset procedure is as follows:-- Reset the alarm by locking and unlocking the drivers side door.Do this a couple of times and then check it will reset the factory security system . If the reset procedure does not helps then its time to get the anti-theft system checked.There is a short circuit in the anti-theft system wiring. For more detailed help on this anti-theft light blinking issues please click on the link below http://www.aa1car.com/library/troubleshoot_antitheft_system.htm
Thanks. you can rate this solution and show your appreciation.
May 18, 2010 | Cars & Trucks
How to reset factory anti theft system dodge intrepid
how to reset the anti theft system for my 2006 dodge ram 1500
Oct 19, 2009 | Cars & Trucks
Microsoft Zune JS8-00001 Digital Media Player Logo
66 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
 Mike M
Mike M
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
