Question about Rug Doctor 95730 MP-C2D Mighty Pro Carpet Cleaning Machine
Need to rebuilt the rug doctor back step by step how do i do it
They took it apart all of it know i wanna put it back together show me step by step
    Top Expert:
  • Rug Doctor Master
  • 10,875 Answers
Make them put it back together
Posted on Apr 27, 2015
Testimonial: "That wasnt helpful buddy they thought they knew what they were doing atleast thats what they said probably to earn a couple bucks they just left it their i need to put it back together some expert i think im Smart enough to tell them that buddy"
  •  johnny rebel
    johnny rebel Apr 27, 2015
    ok,THERE ARE NO INSTRUCTION MANUALS FOR THEM,the company doesnt want you to work on them yourselves,if you need instructions,then call rug doctor,I researched it enough to know that there are no manuals.thanks for the comment,next time dont let children work on 1000.00 dollar machinery.
Tip
I found this very useful. I have a brand new F5914-900 and no other solution...
When the brushes stop spinning on a Hoover SteamVac, it can be caused by several things. In order to diagnosis why your brushes aren't spinning, please view the diagnosis solution I have done on Fixya:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If you have diagnosed your machine, and found that the internal receptacle is not spinning, then you'll now need to replace your turbine. This tip will explain in detail how you'll need to complete this repair.
Here's what you'll need to complete this repair:
- Hoover SteamVac Replacement Turbine Brush Gear (several different parts for different models)
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see-thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to un-clip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before you tighten the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
Chris J.
GoVacuum
on Aug 11, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a new Bissell Powerglide 1305 vacuum. It is red. I took the thing apart screw by screw to clean it inside out after my son decided to vacuum out the fireplace ash. However, once I put it back...
Knowing a little of how mechanical things are designed I would guess that when you took it apart you didn't notice exactly how the mechanism was set up that triggers the reclining feature. I would take it apart again. Then canalize how the reclining mechanism should work. It's probably to pieces that are not fastened together but are only held by positioning on assembly.
Feb 10, 2015 | Bissell Vacuums
How do i put the lid back together on a moulinex serie f30 after taking it apart for cleaning
One shouldn't take things apart if one cannot re-assemble them :D
Take it to your local vac shop.
Oct 29, 2014 | Vacuums
Putting the head back together
its usually quite simple all you have to do it attach the belt that rotates the motor(sometimes there are two) to either end attach them to the tension prongs clip the brush head in place them screw the retaining plate back hope this helps
Apr 07, 2014 | Eureka 439Az Pet Lover Oh Upright Vacuum
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Dec 31, 2009 | Kirby Vacuums
I need to know how to put bissell proheat 2x back together
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ghsgh
Aug 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Rug Doctor 95730 MP-C2D Mighty Pro Carpet Cleaning Machine Logo
443 people viewed this question
Top Rug Doctor Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rug Doctor Vacuum Expert? Answer questions, earn points and help others
