Question about SWANN Home Security
How can I record audio onto the SD card?
The SD card records video but not audio.
  • 1 more comment
  • Verdant Green
    Verdant Green Apr 27, 2015
    It's SwannEye HD. I can hear the audio when accessing it live. I just don't hear the audio when accessing the clips saved onto the SD card from when the motion detector is triggered. I'm using VLC media player, which is playing other videos fine with the audio. Also, audio input is enabled (under audio settings).
  •  Gary Gemmell
    Gary Gemmell Apr 28, 2015
    These cheap ipcams dont record audio.
  •  Gary Gemmell
    Download gspot and check the file you will see no audio is attached to the file.
    Sergeant:
  • 258 Answers
What is the model of the cam?
some cams only do video
depends what its saving the file as
may be your software that wont play the audio but plays the video ok
check the codec used to save the audio
Posted on Apr 26, 2015
Testimonial: "It's SwannEye HD. I can hear the audio when accessing it live. I just don't hear the audio when accessing the clips saved onto the SD card from when the motion detector is triggered. I'm using VLC media player, which is playing other videos fine with the audio. Also, audio input is enabled (under audio settings)."
  •  Gary Gemmell
    What format is the file saved in mp3? mp4? avi? wma?
    Download gspot and load the file and check and see if there is an audio track present - if not then you know the camera isnt working properly.
    I would then perform a hard reset back to defaults.
    I suspect your camera is saiving in mjpeg format which doesnt include audio so you have to choose a different format if this is the issue - avi or mp3 if you can.
    What model is the camera?
  •  Gary Gemmell
    AH I see its a cheap ipcam - none of them record audio dude only live,.
Magnavox NB500MG1F Blu Ray Player: I've been having trouble getting the SD card slot to read the videos I put onto the SD card. I've tried everything from converting all the video files to AVCHD file types...
It is obvious to me that the player can't read the video off an SD drive. In my experience that card slot is for installing updated firmware not video material.
Mar 23, 2017 | Audio Players & Recorders
I recorded something for school and i realized after I recorded it there was no SD card. so it just went to the tape. How do I get it onto the SD card or onto the computer?
You connect the camera to the computer with a firewire cable the open
Windows Movie Maker or similar application to capture the footage.
Apr 29, 2011 | Canon ZR85 Mini DV Digital Camcorder
Have new Vivitar DVR810HD Digital Video Camcorder, loaded SD card correctly but camera does not record onto SD card Help!
Make sure that the video camcorder was not turned off immediately after recording before the images are saved in memory. Also be sure that your memory card is properly inserted in your camera.
Feb 27, 2011 | Vivitar DVR 810HD Flash Media Camcorder
This thing recorded video without audio.
No, sorry. This camera has a small glitch where it occasionally records video without sound, especially if it has been on for a while. In order to fix this, you can simply turn the camera off and on when it is recording without sound.
Oct 27, 2008 | HP Photosmart R927 Digital Camera
I am using an sd card when i hit the record button it says cannot record video on the model number DZ-GX5020
Sorry, but as far as I know, Hitachi camcorders cannot record video directly onto an SD card. You have to set the camcorder to DVD. It can only record video and pictures on a DVD, and only pictures on an SD card.
May 02, 2008 | Hitachi DZ-MV730A DVD Camcorder
JVC GR D770 need help with recording
you cannot record onto the SD card only ontothe sd card for the iamges - snapshots
Jan 29, 2008 | JVC GR-D770 Camcorder
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Home Security Logo
181 people viewed this question
Top SWANN Home Security Experts
gaucherre
Neil Frazier
Neil Frazier
Level 1 Expert
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
