Question about Health & Beauty
My mother gave this scale to me without set up directions. Can you help me set it up?
JI-20636 is in the inside of the battery cover.
  • Julie Walker
    Julie Walker Apr 26, 2015
    The scale I have is a Jobar digital talking scale. I can't figure out how to set it up.
  • 5,631 Answers
I believe JI-20636 is not a model denomination. Couldn't find any reference to it. What is the make of your scale?
Posted on Apr 26, 2015
4 Suggested Answers
r321567499
  • 74 Answers
SOURCE: battery cover
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Posted on Jan 07, 2009
fitnessbalan
  • 59 Answers
SOURCE: Can't set scales
Not sure what model you have but here is the tanita website, where you can look up the model and download the manual from there. http://www.tanita.com/en/personal
Posted on Mar 24, 2009
  • 3 Answers
SOURCE: I just need a place
hi bonniebj2007,
below is the link where you can find the instruction book for your weighing scale.
http://www.taylorusa.com/media/IBs/7544BL%20IM.pdf
Posted on Jul 03, 2011
The conair ww39 requires 2 batteries. When replacing what direction do they go?
Hello (revised)
Revision:
If the batteries stack on top of each other, they have to all go in the same direction. Be sure the flat backs are in the direction toward the spring. The protrusion on the other end of the battery will face away from the spring.
End revision.
It is very common to use the following method.
Look into the compartment and you will see a spring where each battery goes. Place the battery's flat bottom against the spring.
Put the compartment cover back on and test your scale. If the batteries are good and the scale works it should be ready for you to use once again.
Best wishes,
Joe
Aug 25, 2016 | Conair Ww39 Digital Glass Chrome Scale
I have Hanson HX5000 bathroom scales that are showing error message OL. I have replaced the battery and ales no difference - anyone gave any ideas how to fix? Photo for reference
First, make sure the battery is not in backwards. If that's no help, let it set overnight without the battery in it before putting it back in. Also, make sure the unit is setting on a level, solid floor - not carpet (this looks like it's tile, but the grout lines are awfully bumpy-looking. . . If none of these things work, I'd say you got a bad unit. Were there no instructions included?
May 14, 2016 | Health & Beauty
Car shorted out no power will not start
Hello! You'll need a multimeter set on the 50 volts dc scale. Pull the 10A fuse for ECM/IGN...Check for battery on the feed side of the fuse with the key on. If you read 12 vdc then battery is present at the fuse block. If battery is present at the block...carefully pull one fuse at a time and, rather than seeing if it's blown, check fuses with a meter. Set the meter on the X10 ohm scale. With battery at the block; Fuses are blown at the inside block.
If there is no battery coming to the fuse block inside the car; Go under the hood and check the fuses in the main fuse block. Check in the same fashion that was explained earlier.
I believe that the high amperage fuses, as in 60 or 80 amps that feed the ignition and supply battery to the inside fuse block are blown.
Also check for battery at the starter motor. This is a direct supply from +post on the battery itself. If no battery is present there may
be a fusible link installed. Disconnect the positive cable from the battery; Again use the ohm meter set on X10 scale and check to see if this cable is open. A fusible link may be installed between main battery and the red wire that runs through the firewall into the inside fuse block.
If you need further assistance write a comment...I am at your disposal like a garbage truck.
Guru................saailer
Dec 21, 2009 | 1991 Chevrolet Camaro
Replace battery
OK, I just (11/29/09) replaced the battery on Conair TH301S glass scale. You will need a CR2032 (3V) battery, a small (P12) phillips screwdriver, a flat screwdriver and a small twiser (to hold small screws).
On a stable and clean surface (kitchen table, no kids around due to small screws) lay flat upside down the scale.
1) Remove all 6 phillips screws that hold the inner frame.
2) With the help of the flat screw driver unhoock each side of the inner frame (horse shoe shape)
3) Open slowly because there are 2 wires that connect the weight sensors and lay flat on the side.
4) There is an eletrical circuit beside the display, it is being held by 5 very small phillips screws (remove them)
5) The you will find underneath a small round black box held by 3 phillips screws. Remove them, open slowly the top cover and inside reside the battery, pop it up gently with the flat screw driver.
6) Replace the battery, reinstall the 3 screws.
7) Where the display stand, remove the 4 screws of the plastic cover. Slowly remove the cover and the LCD display itself (pay attention on how the display is installed).
8) Re install the circuit board with the 5 smaller screws
9) With a QTips and alcohol clean the contacts of the circuit board where the LCD dispaly sits. Sit in place the LCD display (it will touch the circuit from above) .
10) Place the plastic cover with the 4 screws.
11) re install the frame and put the 6 screws.
12) YOU HAVE DONE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 12, 2009 | Conair Health & Beauty
Unable to pop battery compartnent in Health o meter EVERweigh
The whole top cover which is the part that you stand on (loading platform) comes off. Turn the scales upside down, pull the sides of the plastic cover to unclip the catches and the body can be removed from the cover. Remove the screws to the displlay and there will be a battery compartment underneath the display. Remove the cover to the battery compartment and make note of the battery orientation. Replace the battery in the correct orientation or you will destroy the scales. Repace the battery cover. Scew the display to the body. Press the cover on the body with the display showing through the window.
Jun 05, 2009 | Sunbeam Health O Meter Body Monitoring...
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Problem changing battery for Conair Thinner Scale TH300
My scale is an older model, "can't locate model# in or outside" sticker on back plate is RH697. Scale was purposely setup so that no one can change the battery but a tech. Back plate had no instruct as to where battery is and the 4 small phillips screws were covered with rubber filler. I scraped off the rubber filler and opened it up, inside was a computer board which I took out (6 tiny phillip screws) to get to the battery (it was the expected 3V) the battery was front and back soldered in. That was enough for me, this company is nothing but a bandit forcing you to a tech (est. cost 45-60$) or to make another purchase. True piracy, I'm throwing it out. Make sure when buying anything that runs on batteries that the product offers ease of replacement, I am disgusted with Thinner.
Dec 18, 2008 | Conair WW81 Weight Watchers Body...
Battery cover
Nov 18, 2008 | Conair Thinner Scale by TH208 Body Fat...
Health & Beauty Logo
139 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
