Question about Home Security
How do I reset the code for my Sentry Safe A3550? The Sentry website doesn't even recognize model A3550. Thanks!
  • 10 Answers
SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
Posted on Feb 18, 2008
SOURCE: changing the combination
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You must have the factory combination in order to change the combination that was added to the safe and the factory combination can not be erased if that is the combination you are trying to erase.
All you have to do is press program & type in the factory code 2 times & that will erase the number you created.
Then to add a new combination all you have to do is: press program followed by 5 new numbers. Then to see if they new number works, just type in the new combination & the green light should come on & you have 4 seconds to turn the handle
Posted on Nov 25, 2008
SOURCE: Changing the code on my Sentry Safe S3877
how to change the on sentry safe s3877
Posted on Jan 20, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 80 Answers
SOURCE: I HAVE A SENTRY SAFE A3860 I NEED TO OVERRIDE THE ELECTRONIC CO
http://www.sentrysafe.com
the instructions are located link above.
mj
Posted on Sep 07, 2009
Mother just past away,luckily safe was open at time,but dont know combo to keypad or we haven't found a key,how do i reset code to sentry10 gunsafe
To reset the combination on a Sentry safe, open the door of the safe, delete the existing codes, press the PROG or P key and enter the factory code. Finally, enter a new five-digit number as per individual preference, which is the new user combination.
It is always prudent to reset the combination on a Sentry safe when the door is open because it prevents the user from being locked out. To open the Sentry safe door, type the five-digit factory code given in the owner's manual. This factory code cannot be altered.
To delete the existing codes on newer models of the safe as of 2015, press the P button. Then, type the factory code and follow it up by inputting "00000" into the safe. On older models of the Sentry safe, press the PROG button and type the factory code two times.
After deleting the existing codes, press the PROG or P key and then enter the factory code once again. Within five seconds, type a new five-digit number, which is the new user code. To verify if the user code is working, retype it and then close the door of the safe. The user code is the primary code for opening the safe, and users can reset it as often as they want too
Mar 21, 2017 | We Home Security
How do i reset the code on my sentry safe
Hey.
What model safe is it?
I have found a link to the Sentry safe website, where you can download product manuals for the safes. It is likely that you'll find information on code resetting there.
If you can provide anymore information in the mean time, I can also take a closer look to see if I can find the information out for you.
Thanks Sentry Safe Product Manuals
Jun 20, 2015 | Home Security
My v260 sentry safe has no power, even with new batteries. I do have the key though, is there way to reset or get into my safe?
Sentry is a very responsible company. Contact them on this web page. Have you're serial number and model available.
Sentry Safe Keep It Safe
Jan 04, 2015 | Home Security
I have a sentry fw123cs safe. It's open but i can't find the owners manual to ock and unlock i
Go to the Sentry safe website, http://www.sentrysafe.com/CustomerCare/Find_Your_Safe and click on "lost your combination" and they should be able to help you retrieve yours.
Aug 29, 2014 | Sentry Safe SentrySafe Model SFW123CS...
Change code sentry
Did you try to tale out batteries for a minute, I hope it`s gonna reset the code
http://www.ehow.com/how_7371620_replace-batteries-sentry-safe.html
Dec 17, 2013 | Sentry Fireproof Safe
I have changed the battery in my sentry 1610, no I can't open it with my pin-Nr..
if you have changed the batteries, the code may have reset itself to the default code.
you should be able to find this in the instruction manual or on the manufacturers website.
i am sorry i cannot give you the codes myself, but i do not feel it is appropriate to put default codes for a safe on an open website
Feb 28, 2011 | Sentry Safe Fire-Safe Home/Office Safe
Need to open a Sentry keyless combination safe
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Apr 10, 2009 | Sentry Fireproof Safe
Sentry Safe A3750 won't open new batteries
call them
mj
Feb 22, 2009 | Home Security
SentrySafe DA3930 Biometric Fingerprint Safe Item Number 681814 will not recognize my finger print!!!! I have been trying to get into it on and off for 3 months. Is there a reset code???
contact sentry
biometric scanners DO NOT WORK
prove your ownership
and they may assist you
and
Sep 14, 2008 | Sentry Fireproof Safe
Home Security Logo
106 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
