Question about Proscan 7" Touchscreen Internet Tablet Capacitive Screen w/ Case & Keyboard in Black
My proscan tablet's power button was slowly getting pushed in, and now it is completely pushed in I tried to pull it out but it just goes back in and I can't turn it on. What do I do?
Model number: PLT7100G(B)
    Problem Solver:
  • 25 Answers
By a no touch tablet
Posted on Apr 26, 2015
My son has a proscan tablet PLT7810K the power button slowly became pushed in & Maybe something wrong with charge port it will not turn on at all it will not charge when put on the charger plz help me
Proscan is classified as a bargain tablet in the low end range.so you should expect any kind od issues related to it. like that of power button.
Obviosly you have a problem with your battery, though no way to tell "from distance" if it's prperly the battery or the charger... or both You haven't commented in your post if it works with the power adapter. Chargers can be easily diagnosed by measuring output with an electronic tester. Once you have a good charger, you should test if you can charge your battery.
I understand that Proscan batteries are "lifetime", so it's not easy to replace them.
You should evaluate it it's worth to buy new charrger and replace the battery or maybe buy another device. Probably you need some technical assitance for diagnosis.
Take note that you can get a used tablet from Amazon from about 465 USD in good conditions, without the need of spending on repairs
Amazon com Customer Reviews Proscan 7 Inch Android Internet Tablet...
Proscan 7 Inch Android Internet Tablet Capacitive Touch Screen Android 4 1...
Oct 07, 2015 | Tablets & eReaders
How do I get the message unfortunately com.android.phone off my sons proscan tablet?
Have you tried the reset with the paper clip in the reset hole yet.?
I think the reset hole is on the back. Press gently into the hole with a paper clip.
You will lose all data however and it will go back to factory default settings.
This is a common problem with Proscan tablets. Make sure you charge the battery fully before starting.
Jan 08, 2015 | Tablets & eReaders
My proscan tablet is locket and ican't unlocket it what can i do???
Since I don't know which exact Proscan Tablet you have, here is how to restore the PLT9045K.
1) Make sure the tablet is powered down.
2) Press and hold VOLUME UP(+) and DOWN(-) buttons, plus POWER button all at the same time.
3) Insert a metal pin in the RESET hole at the back of the tablet, then push and hold it for 2 seconds, while still holding the VOLUME and POWER buttons. Make sure the pin is pushed. It seems like nothing happened, but just keep on going to the next step.
4) Power ON the tablet and immediately, PRESS and RELEASE continuously the VOLUME UP(+) button in order to get the display as showing dead tablet (dead robot).
5) This is the critical part. Make sure you do the right sequence or you will start again from the beginning. Press and hold the POWER button, then press and release VOLUME UP(+), and the display will give you a screen showing different options.
6) Choose the option wipe data/factory reset, by clicking POWER button to scroll down. To execute the selected option, press VOLUME UP(+) button. The tablet will reboot back to its factory setting.
Jul 12, 2014 | Proscan 7-Inch Android Internet Tablet,...
Proscan PLT8235G stuck on blue screen. Reset button just shuts tablet off, and problem still remains.
I have had the same issue with this tablet. After weeks of looking around on the net i have found a way to reset the tablet to factory settings when the power and vol down button will not work.
1. Download the firmware from the proscan website. http://www.proscanvideo.com/item.asp?itemnmbr=PLT8235G.
2. unzip the file and copy the files update.zip recovery.img and factory_update_param.aml to an external micro sd card.
3. Plug the tablet in and insert the sd card. Press the power button to see the battery icon then press the power button 5 times. Then let it run for 4 minutes and it should be set back to factory settings.
****NOTE***** If it fails to update then you still have the access to the recovery menu where you can do the factory wipe and still reset it.
Hope this helps.
Apr 02, 2014 | Proscan 8 4GB Android 4.1 Tablet
Proscan tablet is frozen
Check for the reset pin hole on your tablet. Get a paper clip and push it 'gently' in the hole and hold it for thirty seconds. This resets the tablet.
Youdon't want to push hard as there is just a tiny button in there that can get dislodged.
Mar 02, 2014 | Proscan Recertified - PLT7035 4GB NAND...
I have locked myself out of my tablet
You will need to do a factory reset:
Oct 29, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Help how do hard reset my proscan tablet plt7035 i for got my pattern to unlock it
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Oct 19, 2013 | Proscan Recertified - PLT7035 4GB NAND...
I have to reset a proscan tablet plt7044k that is locked up with a pattern password that i have forgot do you know how toreset it
Steps on how to reset the Proscan PLT7044K 7" android tablet.
1. Hold down the power and volume up buttons at the same time until you see the android logo then release both buttons.
2.Hold down power button then push the volume up button once for the reset menu to appear.
3.Use the volume down to select the factory reset to reset all data.
4.Reboot the device after reset has completed.
Mar 29, 2013 | Tablets & eReaders
Proscan 7" Touchscreen Internet Tablet Capacitive Screen w/ Case & Keyboard in Black Logo
122 people viewed this question
Top Proscan Tablets & eReaders Experts
CrisO
David Payne
David Payne
EE Eddie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
