Question about Vehicle Parts & Accessories
1981 What tail shaft do I need 350 turbo trans.
I have a 350 turbo trans what tail shaft do I need to convert from 4x4 to 2 wheel drive and do way with mp208 transfercase
  • 46 Answers
You need to measure the shaft length with the transmission slip yoke installed in the transmission, get it in the position you want to have it at where its connecting to the differential/hogshead as close as possible. Now measure from the center line of the universal bearing on the back of the transmission yoke to where it will connect to the hogshead universal bearing. You need to be really close with this measurement and probably no more than 1/4" (6-7mm) off and just a bit short is better than to long because the transmission yoke can only slide in or out so much before you change the geometry of the alignment and start causing excessive wear and damage plus vibration (like you think its going to fly apart vibration which it is! so get the measurement right) Now you got lucky because I work in a drive-shaft shop right now and I've done a couple hundred of these in the past year for everything from dump-trucks to electric golf carts and 4-wheelers. You didn't mention if it was a 2 piece drive-shaft with a center bearing but with it being 4wd it probably has one plus a squirrel cage idk but you've got little room for error on those especially if it needs rebuilt, it should not sit flat or straight out but kinda bent at an angle because that's how it runs most of the time. So if it doesn't and just kinda flops around it needs rebuilt with new universals and pivot bearing/post possibly. OK so when you get that measurement take it to the drive-shaft shop and have them either cut yours down to length or extend (I dont recommend that, the shaft will have to be rebalanced because it will vibrate and that is an extra charge) the length or make a new one. Go with double-strength tubing and always use new yokes and universals. Good luck
Posted on May 25, 2015
What is required to remove the transmisson?
Well......it depends on the application....997 twin turbo 911....or a chevette.....
Apr 02, 2015 | Cars & Trucks
Can I switch out the 700 r transmition for a turbo 350
as long as u get a turbo 350 trans that is the same length from bellhousing to tailshaft u should be able to. the only thing is the 700r trans has a t.v. cable to control the shift where as the 350 has a vacuum line that goes to the modulator on the side of trans. if your not 4 wheel drive u might have issues w/ speedo being electric vs. cable
Jan 17, 2012 | 1988 GMC Jimmy
I need to replace the turbo 400 tranny in my chev 3500 4X4 silverado. I see lots of turbo 400's on craigslist. How do I know which ones work for my truck?
Four wheel drive th400 only,do not fool with having to change tail shafts,and out put shafts,look for one that was in heavy trucks.
Nov 13, 2009 | 1989 Chevrolet C/K 3500
1979 firebird transmission swap question
As long as the transmission tail shafts are the same it should fit nice . check the tail shaft (not drive shaft) they are interchangable if it is longer or shorter.
Sep 02, 2009 | 1979 Pontiac Firebird
No movement in any gears
thats a real simple unit, either the pumps input shaft sheared or the drive hub that that shaft engages into the torq converters spot welds broke. happens on rebuilt torq converters from time to time, either way its gota get pulled. a 2wd is very easy to remove and cheap to repair good luck!
Aug 26, 2009 | 1986 GMC Suburban
Speedometer does not work 1991 GMC Sierra 2500
the turbo 350 doesn't have a output speed sensor like the trans that came with the truck orginaly. You will have to use a cable to drive a pluse generator,or switch the tail shaft housing with a 700r4e housing of the same length,and use the speed sender from the 700r4e or early 4l60e. note the tail shaft is the same splines but the 350 shaft detent hole my not line up with the relucture ring. therfor the output shaft needs to be change to, or have a relucter ring made.
Apr 03, 2009 | 1991 GMC Sierra
Pressure but no mechanical power with all gears on THM 350 Trans
Possible that you could have a bad torque converter, or your input shaft splines are sheared off.
Apr 01, 2009 | 1987 Chevrolet El Camino
Vehicle Parts & Accessories Logo
59 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
